Question about Rowenta DG5030 Iron
Where can I purchase a replacement on/off switch assembly?
  • cshinkson Nov 12, 2015
    Try ereplacementparts.com (part #: CS-00098585)
Shark iron leaks water from the bottom of the body where the power cord come out. could it be a crack in the holding tank? Is there a way to fix it,or will I need to purchase a new iron?
It is hard to assess what would be the cause, but I think your diagnosis may be correct, of a possible crack, or a tube has come loose. You tube has instructions on how to disassemble and iron if you are up to it and have the tools. Then you'd have to order a replacement part, and re-assemble. I'd just go to walmart & buy a new iron! But that's me! :)
Iron Disassembly Process
Nov 16, 2016 | Irons
Switch not working hoe can i replace
Good evening Melinda!
You can look here for replacement parts
Rowenta DG5030U0 B80 Pro Master Iron Parts , (amongst others), and a closer look at the 'Housing, front complete'
Housing Front Complete shows it includes an on/off switch.
It's not a 100% match, but this video showing dis-assembly / troubleshooting another Rowenta iron will probably get you to where you need to to replace the part (and might allow you to see if it's just a disconnected/broken wire and save the $17 for the part!)
Hope this helps, and good luck!
D
Nov 19, 2015 | Rowenta DG5030 Iron
Please advise me on problem with corby trouser press I purchased this and fitted it as suggested switched it on it looked fine but after a couple of miniuts it shut off i checked the fuse and it had blown...
if the purchase was recent -- put back in its box and take it back to the store. If it is not feasible to return it to the store, call the manufactures customer service section and tell them you have and electrical fault within in the press. They should replace it no cost to you. If you cannot get satisfaction - file a complaint with Fed Gov Consumers watch dog
Jan 29, 2015 | Irons
Rowenta pressure iron and steamer model DG5030? We have purchased the iron and cord, now we need to assemble the part.
Google Rowenta and go to their website, they will have parts diagrams and wiring diagrams. Hope this helps, please post solved on fixya.com. So I get credit for a solved problem if it does.
Apr 30, 2014 | Irons
Tefal steam generator iron
follow this steps and fix it. God bless you
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Nov 24, 2013 | Irons
Power switch blew
you can go to small appliance.com and buy a
new switch. i have do this and orther parts .
for the same model.
Aug 27, 2009 | Rowenta DG-980 Iron
Power chord frayed and I need a new one for a conair hair iron CS36. The chord pivots in the handle 360 degrees.
go to (www.fixit.com/small apliance)
what I found out with my hair dryer (conair infinity model) was that there was a short at the plug and when I bent the wire a little to left or right the dryer would work. The plug is GFI protected that means there is a test and reset switch built in to the plug. There for for me to fix my hair dryer I would have to replace purchase order the whole cord. The cord assembly cost almost half the price it would cost to replace the dryer with a new dryer. I purchased a new dryer.
Dec 26, 2008 | Conair Dry 'N Straight Hair Dryer and...
Rowenta dg980
I found out that you do not need to remove the security torx screws (you can get a set from Kragen's Auto Supply or Harbor Freight Tools); don't mean to advertise, but they have decent prices for any "Do It Yourselfer' arsenal." Use a wooden popsicle stick and gently pry the soft rubber cover from the front (on either side) toward the cord end, just enough to access the trigger/control switch assy from the top. Good luck and keep in touch.
Jul 07, 2008 | Rowenta DG-980 Iron
Rowenta dx6700
The wire inside the cord is likely torn ant it connects and disconnects as it is moved back and forth. This happened to me too. I just need to find where to get a new cord.
Sep 23, 2007 | Rowenta DX6700 Iron
Rowenta DG5030 Iron Logo
283 people viewed this question
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
