Why Bosch Maxx WFL 2260 no power? - Washing Machines
  • 142 Answers
SOURCE: Bosch Maxx WFL 2260 not draining - nothing in filter - help?!
sounds like a simularproblem i had, a 5cent piece got caught in the drain solenoid (just between the drum and solenoid) , i had to lift up the front and spin the drain pump fan, on empty, then disassemble and clean pump assy and remove 5cent piece, hope this helps.
Posted on Jan 25, 2009
tony2155
  • 64 Answers
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
Posted on Mar 28, 2010
  • 7 Answers
SOURCE: I have a Bosch maxx wfl 2260 and the machine has
Check the brushes in the big motor- I think you can do that without removing the motor. If they're used up, replace them. If that doesn't fix it, there's an internal fuse in the motor which is not replaceable, but in emergency you could bridge this with some wire and see if it fixes the problem. If it does, you should get a new motor otherwise without a working fuse it might one day take out the rest of the washing machine, and you house fuse!
Posted on Apr 03, 2010
SOURCE: need instruction manaul for bosch wfl 2260
Programmes appear to be taking excessively long time to complete even with the quick wash button pressed - 2 hour 15 min for 30 Cotton wash cycle. Is this right or is there a fault? 30 Easy-care seems to be taking almost as long.
Posted on Aug 11, 2010
c_dahlin
My drum stop, then I put in new carbon brushes. It works very good in 2mouth, now it stop again. Wht can be problem?
Posted on Feb 07, 2013
How to fit bearings in wfl 2260 bosch max washing machine
dose drum has to come out also replace element
Mar 02, 2015 | Bosch Washing Machines
Maxx WFL 2260 wash. machine will not fill/spin
Could be the intake valve solenoid, or control panel fault
Mar 26, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing machine i not draining out. bosch maxx
Mar 28, 2010 | Bosch Washing Machines
Need instruction manaul for bosch wfl 2260
May 17, 2009 | Bosch Washing Machines
Jan 25, 2009 | Washing Machines
Maxx 2260
I fixed a y joint to the cold water outlet and fed ito both hot and cold on the machine
tks
Sam
Nov 28, 2008 | Bosch Axxis WFL 2060 Front Load Washer
Bosch Maxx WFL 2260
Jan 17, 2008 | Washing Machines
Bosch Maxx WFL 2260
thanks sorry i have no hands on experence with bosch as im in usa and dont have many in my neck of the woods but there are bosch experts in here
Goes through washing cycle but doesn't dissolve the tablets or cleans the clothes.
Clean out your outlet filter; this is to be done regularly once a month, depending on your usage. Re your tablets not disolving, try using front loading washing powder. Also refer to your manual..........
Jun 10, 2007 | Bosch Classixx WFL 2066 Front Load Washer
Washer only seems to work on 40 degree cycle
check to see if this model has 2 water inlet hoses
if there is 2 only 1 may be used and is connected to hot tap thus only letting in hot water when machine requires water
Jan 03, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
