Question about Sport & Outdoor - Others
Disadvatages of build new cinema campos in our local area
How to . write introdution
this is a repair website. we dont write anything except answers to repair questions here
Mar 17, 2018 | Computers & Internet
Timber fences,
recommend contacting your local council.
Depth varies on winds likely to be encountered in your area
Council may require a building permit
http://www.fencingonline.com.au/boundary/paling-fence-guide01.htm
would think 900 mm as your fence is higher than normal but depends on cyclone rating of your area . spacing between the posts also needs to be considered.
recommend checking local fencing depth regulations
Soil types also determine depth
http://www.timber.net.au/images/downloads/exterior/timber_fences.pdf
https://assets.mitre10.co.nz/sys-master/images/h90/h58/8842109747230
Jul 17, 2017 | Saws
Where can repairs be done to the Main Unit of a HT-TXQ120 Digital Home Cinema System
most electronic shops that repair tvs can repair your unit within 1 or 2 days tops...they get capacitors or resistors off ebay or local vendors in your area..main units( I am assuming you are speaking in regard to the main internal power board) are easily repaired around 50.00 and up...I know it is a lot of money for soldering in a new replacement part..but if you love electronics like I do, it is not bad to get your favorite toy back...good luck
May 19, 2017 | The Audio Players & Recorders
Refridgerator goes offline
Do these outages happen regularly? Is electricity supply unreliable in your area?
Do the lights just dip in brightness or do they go completely off? (Brown out instead of black out)
If you are having supply problems in your area, you should talk to your local power utility company.
If this is a new build and there is a fault in your electrical installation, the company who installed it should repair it at their cost.
It's important to know the limitations of power supply in your area. You may discover that something else in your house is drawing too much power and tripping your supply. You will need to pay for any fix in this case.
Your local power utility company may be able to provide advice on how to address this issue.
Apr 16, 2014 | Samsung Refrigerators
I AM TRING TO FIND OUT HOW I CAN BUILD A BRICK BBQ PITT SMOKER SO I CAN SELL FOOD OUT OF SMAALL RESTURUANT
Here's a link that will provide over 200,000 sites for building a brick BBQ pit/smoker. Will all work for what you want to do? Probably not, but it's a good place to start. Also, you will want to consult with your local building inspection office, to be sure that whatever you build will meet the local building codes in your area.
http://www.google.com/search?q=building+a+brick+bbq+plans&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
Feb 14, 2011 | Grilling
My son cannot get robin over the fence/gate - i am clueless as to how to help him. r there not instructions for these games? any help is appreciated!
Hope this is what you are looking for:
Use the D-Pad to move around
Y is to shoot or swing your weapon, or just hit with your fists
A is to use switches, pick up objects, build LEGO objects, use the Batarang
B is to jump
X is to Tag between characters in the game.
L and R are to switch characters in the freeplay mode and some parts of the
story mode. You can also use the Touchpad to switch characters.
See the character abilities section for more inforomation.
Vehicle controls
D-Pad to move, press down to slow the vehicle.
X is to use the Boost rockets, you need Boost Energy to do so.
Y is to shoot.
I think this is the part where he is stuck...
You will see
a Blue Brick Machine in the area. Gather the 2 Blue Bricks nearby, and step on
a circular floor switch to get the 3rd one. Placeing all 3 of them on the
machine gets you a Grapple Spot to build & use as Batman. Build & use a wall
switch to get a ladder to build for Robin to climb up. Switch to Robin and
head towards the back of the ledge to build a Tightrope. Cross the Tightrope
with Robin to get to the top of the Cinema. Build & use a wall switch to open
the door near the gate that is locked. Go into the door & use a wall switch to
open the doors to the cinema. Switch to Batman & Bomb the Red box in the lobby.
This gets you 2 circular floor switches to build. Step on one, and your partner
will step on the other. This makes a ladder to build appear, carefully avoid the
green stuff in this area, cause you are not immune to toxic & climb the ladder
and Bomb the lock on the gate to get it open.
Oct 10, 2009 | Warner Bros. Interactive Lego Batman for...
Need owner's manual for Baldwin Cinema II organ
I have the original technical data for it, as if you wanted to build one yourself from scratch, but no owners manual. Did you ever find an owner's manual? Also, I have the organ itself.
Oct 07, 2009 | Music
Disadvatages of window programming in vc++
in visual C++ meaning you need to understand MFC.. and win32 to create application.. try C# asp.net for easier way to create windows application...
Sep 28, 2008 | Computers & Internet
Sport & Outdoor - Others Logo
61 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
