Question about Samsung WF306BHW High Efficiency Front Load Washer
Wshing machine keeps running and stays at nine minutes
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
Dryer won't stay running without holding down the start button
It may be the centrifugal switch on the motor. The push button starts the motor and as the motor spins up to speed the centrifugal switch closes to keep the motor running. Hope this helps.
Jan 02, 2014 | Admiral Dryer. 6.5 cu. ft. Electric Dryer...
Washing machine dances around the kitchen. with a
Grease tank suspension springs , make sure feet adjusted so no rock in machine
Sep 23, 2013 | Arrowhead Brass 4663381 Wshing Mchne Vlve...
I WOULD NEED THE USER MANUAL
Hi sansz,
Plz specify the brand name & model no of your Wshing Machine to get a specific manual.
Thanx
Aug 24, 2011 | Zanussi Washing Machines
The machine is not spining properly and leaving wshing wet
when machine is empty turn on side and check underneath for slipping or broken belt Replace . hope this helps
May 17, 2010 | Washing Machines
Hotpoint BWD 129 machine starts to fill -
Try on a cold wash or rince cycle, if this then works it could be faulty heater element.
Feb 12, 2010 | Washing Machines
Wshing machine operates but does not rinse and speen.
Try cleaning the filter if its not pumping out water this causes no rinse / spin
Oct 02, 2009 | Washing Machines
Maytag wshing machine just stopped working, won't turn back on
Open the top console panel to access the spin/start switch and reset the start switch. If that does not work, replace the start switch.
Jul 11, 2009 | Maytag Dependable Care LAT9706
Samsung WF306BHW High Efficiency Front Load Washer Logo
27 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
