Question about Bosch 11224VSR 7/8" Hammer Drill
Does any one know what could be the part to replace wen the drill is not hammering on a bosch drill hammer 11224vsr
3 Suggested Answers
  • 885 Answers
SOURCE: Bosch 11224VSR drills and hammers but not both. Makes loud stripping noise.
If both functions, hammering & drilling, work correctly on their own but not together your selector knob may be the issue. On the back of the knob is a driver pin that moves the necessary parts to make your tool drill, hammer, or both. If it isn't moving those parts to the exact right place, one or more of the functions may not work. Try moving the selector halfway between positions and see if the gun hammer-drills. If it does you have problems with the selector or drive pin. If it still does not you may have internal parts problems that can only be diagnosed by working on the tool with the knowledge of how it works and how everything inside should be.
Posted on Apr 20, 2012
jeffpetree
  • 36 Answers
SOURCE: Hammer function does not work on Bosch 11224vsr
Its usually a problem with the selector knob... depress the button fully and turn it passed the selection markings and pull it out to remove it
Posted on Dec 09, 2012
What type of oil for bosch 11224vsr rotary hammer drill
special grease is used not oil order number 1 615 430 001 is the right grease for it
Apr 08, 2013 | Bosch SDS-plus BULLDOG Xtreme Rotary...
How do I remove the striker pin on bosch 11224VSR
If you mean the front striker pin you will need to remove the circlip up inside the spindle. You can see it through the two little holes just above the spring.
Nov 06, 2012 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
Aug 29, 2012 | Bosch Factory - Reconditioned 7/8" SDS -...
Hammer drill won't hammer
Without knowing which model you have: Most Bosch hammer drills use a plastic connecting rod to attach the piston to the rotating spindle. These are a common failure item and fairly easy to replace.
Jul 18, 2012 | Bosch Drills
Apr 19, 2012 | Bosch Drills
Faulty bosch hammer drill
a bad trigger switch; bosch sells a replacement part
Jul 24, 2010 | Bosch Drills
Hammer drill quit
If it is an 1199, forget it. Replace the brushes and do NOT use for hammering. It is a design problem. My unit was repaired 4 times and hammered about 5 holes each time before same failure.
Jul 02, 2009 | Bosch 1617014127 Brush Set For 11224vsr
Bosch VSR 1199 hammer drill keeps slipping in hammer mode
Inside there is a little plastic shaft, where the selector hooks to. They have had problems over the years stripping. Replacement part is still plastic. Yay! You may need a bearing puller or find some way to get the clutch off the shaft. Lemme know. Please rate me
Jan 26, 2009 | Bosch 1199VSR 8.5 Amp 1/2 Inch Hammer...
My 11224VSR is working but has lost most of its hammering power.
You have to keep the shanks of sbs bits clean and lightly greased. When you snap the bit into the chuck, the bit should move freely in and out between the retainer and the hammer head.
Nov 24, 2008 | Drills
Bosch 11224VSR 7/8" Hammer Drill Logo
Top Bosch Air Tools & Compressors Experts
John Trevino
Jim Goldsmith
Jim Goldsmith
Are you a Bosch Air Tool and Compressor Expert? Answer questions, earn points and help others
