Question about Sharp AR-M205 Copier
What do i do if i make photo copy and the gears sounds
When the paper reaches the heater, it makes a cracking sound and prints wrongly on paper. it prints double character on one character space. what do I do?
  • 71 Answers
The fuser gears brake alot on these because of the heat. Open the flip down cover on the fuser when it is cooled off and try rotating the roller by hand look into the right side to see that the gear is rotating with the roler if not your sharp dealers should be able to get you the part for around $22 and they could put it in for an hour of labor.
Posted on Jul 14, 2014
  • 18 Answers
SOURCE: My copier makes a noisy sound
paper pickup clutch spring slipping, cause by toner leaking from toner unit. strip and clean clutch spring or replace.
Posted on Oct 08, 2007
  • 53 Answers
SOURCE: sound during paper take up.
is it a clicking noise? If so, pull out the toner unit and the drum unit-is there any toner(and developer) spilled into the back of the machine where the toner unit came from? If so, this will have found its way into the feed clutches at the back causing them to jump gears and slip the drive....you can vacuum out the spill but it is a fairly involved job to clean out the clutches, let's just hope I'm wrong.Other than that more info is required to make a half reasonable guess at the problem
Posted on Feb 09, 2008
  • 29 Answers
SOURCE: grinding noise
my suggestion is replace the fusing gear and the rachet gear.
Posted on Mar 25, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Sharp AL-1642CS making blank copies
You have a door on the right side of the machine. in that door is a thin piece of wire mounted inside a bracket. The bracket is white and is at an angle in the door. Do you see that now?
Posted on Jul 18, 2008
keithd2704
  • 56 Answers
SOURCE: double left line down the side of paper
Sounds like the drum surface has been damaged by some foreign object.
Typically when you get imaging errors such as lines from top to bottom of a page there is a permanent scratch on the drum surface. Pull the drum unit out of the printer/copier and carefully examine the drum surface, you most likely will see the damage quite easily. The only repair is to replace the drum unit with a new one. HOWEVER... be sure to clean the inside of the machine with a toner vacuum to remove any dirt, debris or paperclips, staples, etc that might have accidentally been introduced into the unit.
Hope this helps you out.
Cheers,
Keith
Posted on Dec 07, 2008
Canon imageclass d340 making a loud clicking sound
It sounds like you may have sheared a gear tooth off the roller drive or the traversing mechanism. If you are getting copies just leave it alone.
Oct 12, 2016 | Canon imageCLASS D340 All-In-One Laser...
In the middle of printing out 8x10 photos, it stopped picking up the photo paper. Makes a grinding sound twice, then beeps error.
Hello Lynell,
Unfortunately, printers only last for about 3 years or up to 5 years if it's a more expensive model. Try a Google search or YouTube search for DIY repairs on the model you own. You may find some helpful information on how to repair your printer. Or, it may be time to get a new one. If that's the case, see if Best Buy will give you a trade in price on something new. Best of luck!
Feb 25, 2015 | Office Equipment & Supplies
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
My HP LaserJet 4L printer just makes a grinding sound-won't print
That printer has a gear on the motor that cracks. You can fix it with a new or used motor. Or get a different machine on craigslist. Thank you, Steven 805-520-3003
Jul 26, 2010 | HP LaserJet 4L Printer
Copier jamming/copy printing sideways
If it jams every copy then it sounds like the paper tray size is not programmed properly. This is also why the print is the wrong direction on the page. So the copier thinks it has 8.5X11 loaded like this > -- and instead it is loaded like this > |
I hope that makes sense. So this not only causes the print to be the wrong direction but since the paper dimension are different that what the machine expects then it throws the sensor timing off and results in a paper jam. So just open your paper trays and check the paper size dials in the trays to make sure they match the paper size AND direction of the paper loaded into that tray.
Good Luck and Thank You for using Fixya.
May 13, 2010 | Canon imageRUNNER 2200
Prints only top half of photos on top half of
I suggest that you go into the printer properties section on control panel. There Will be a section which allows you to tell the printer the type of paper, size desired, orientation of photo to horizon and etc. There is also likely a selectable setup procedure on the printer's own display to do the same... It sounds like a basic setup format issue....
Apr 02, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Machine started making a loud clicking sound and wont copy
fuser roller gear is cracked... or a spring holding the bypass is loose
Dec 11, 2009 | Sharp AL-1641CS Laser Digital Copier
Ink Color Issues
Did you change any of the configurations on your printer. Most photo printers have color settings that are media dependent. It sounds like you might have it set to print on regular paper but not on photo paper. There are a lot of settings that you can accidentally change on a printer so I would suggest uninstalling the printer then reinstalling it and see if that is the issue.
Sep 11, 2008 | HP Photosmart 3210 Printer
Paper Jam - now terribly noisy!
Fuser gear cracked from the sound of it or non oem or recycled toner cart that is too stiff to turn correctly
Dec 12, 2007 | Brother MFC-8440 All-In-One Laser Printer
Printer and Making Copies does not work!
Will the machine run a paper path test?
This sounds like it could be a sensor indicating a paper jam, if this is the case, it won't run anything through the paper path (not even a blank page).
Nov 26, 2007 | Sharp UX-B20 Plain Paper Inkjet Fax
Sharp AR-M205 Copier Logo
43 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
