Question about GE GTWN4250MWS
Why is GTWN4250M1WS damage wash - GE GTWN4250MWS
My GE top loading washer continues to fill while lid is up for loading.
fix the safety switch for the lid
all operations are to stop when the lid is opened
Dec 24, 2017 | Washing Machines
Top load washing machine damaging cloths
In what way are they getting damaged, and is the machine under warranty?
Apr 18, 2017 | Amana Washing Machines
During wash machine keeps either beeping displaying E10 or automatically pauses. We have checked the filters with no blockages identified. Drainage hose is not low so water is escaping.
if LG:
ERROR DISPLAY [E I ] Leakage error. Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
Apr 01, 2015 | Washing Machines
Ipod washed in washing machine
Throw it in a bag of rice PRONTO! If that doesn't work, call 1-800-MY-APPLE & find out the out of warranty price. Little known fact, Apple does not warranty drop or water damage, but unlike other companies offers cheaper than brand new replacements/service for accidental damage up to a damage threshold.
I’m happy to help further over the phone at https://www.6ya.com/expert/clint_f00dc48f472715e0
Apr 30, 2014 | Apple iPod touch
Why do my glasses go cloudy
All glasses eventually go cloudy in dishwashers, the problem is far quicker and more noticeable with lead crystal which specifically should never be washed in this way.
The cloudiness cannot be reversed: it's caused by millions of tiny cracks in the glass surface as a result of both the chemical and physical processes inside a dishwasher. Some products claim to include a "glass protect" function, but it just slows down the damage instead of stopping it. Commercial glass-washers used in bars and restaurants also cause this damage, but as the wash cycles are far quicker and the cleaning agent is specifically for glass the damage occurs more slowly. In any case, glasses don't usually last long enough in commercial use to show this damage as they usually scratch, chip, or break before it shows.
All you can do to totally avoid the damage is to wash glasses manually and to never put lead crystal in the dishwasher. If that's not an option, then you can slow the damage by washing glasses at the lowest possible temperature: you'll find that some cleaning products are better than others at low temperature and it's not always the expensive brands.
Sorry there's no fix for your cloudy glasses, but I hope that I've helped to to avoid further damage. Please take a moment to rate my reply.
Sep 08, 2010 | Miele 24 in. G643Vi Plus Built-In...
Washing machine is making a clicking/ticking sound when it is agitating during wash cycle
This is a sign of strained agitator components that are about to be damaged or stripped. I recommend pulling the agitator and clutch. inspect each device for stripped components and uneven ware. replace the agitator and clutch if found to be faulty.
Check the transmission(gear box) for damage as well. fill with oil if needed.
May 27, 2009 | Washing Machines
During wash cycle the tub doesn't lock.
Lid lock may be damaged. Unplug, remove the front by the bottom 2 screws. Look at lid lock to see if it has overheated or damaged. Let me know, Thanks, Sea Breeze
Mar 10, 2009 | Frigidaire GLWS1233A Top Load Washer
Our brand new bosch exxcel washing machine is jumping all over the place. We have checked it with a spirit level and it is level. The feet are tight. The washing is loaded level. What is wrong ?
hi The drive belt (or belts) of a washing machine may become worn or damaged, causing noisy operation or stopping the washer entirely. A damaged drive belt is easy to replace. Remove the back panel of the washer to gain access to the belt.
Sep 12, 2008 | Bosch Washing Machines
GE GTWN4250MWS Logo
27 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
