Question about Dometic NDR 1292 Refrigerator
The board shows an upside down u, the customer has been told that frige is in lock up mode
    Top Expert:
  • Dometic Master
  • 8,487 Answers
Check voltage at back if ok bad control board
Posted on Jun 18, 2016
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Nov 08, 2017 | Televison & Video
Purchased a new board and picture is upside down and colors are way off. Company stated that I needed to enter into service mode to adjust.
Contact the customer support area of set manufacturer for assistance in getting into service mode.
Oct 14, 2015 | Televison & Video
Display is upside down
hi,
it sounds like the tinny switch that detects the rotation of the LCD is blocked on the 180 degrees mode. it can be fixed but you need to disassemble the cam ! or may be try a little shock near the hinge... sometimes machines need a little kick !
Apr 04, 2014 | Sony Video Cameras
How to fix upside down screen on led tv
Time control board or lcd panel itself. Some times you cannot get the t con board. it may only come with the LCD panel. Check Shop Jimmy website.
May 29, 2013 | Vizio E390-A1 39" 1080p 60Hz LED 2.95"...
Picture shows up side down
If the picture shows upside down with the projector sitting on its feet projecting forward, then it is in ceiling mount projection mode. Page 58/84 of the User Manual explains how to change: Menu; Options(2); PRJ Mode; Front; Enter
Jan 18, 2013 | Sharp XG-PH50X Multimedia Projector
When i try scanning ,am being told switch lock has been locked,detach USB then when i click ok an being told twain error has occurred and scanner cable not connected.HOW CAN I SOLVE THAT PROBLEM?
In most scanners, there is a lock (usually on the bottom side) to protect the internal parts while transport.
Detach the USB and power, turn the scanner upside down and unlock the button.
Attach the cables and retry.
Best of luck!
Aug 30, 2011 | Canon CanoScan LiDE 30 Flatbed Scanner
Shelf removal
turn it around or upside down
Sep 20, 2009 | Maytag MZD2667HE Side by Side Refrigerator
Upside down image and only half showing on screen
cheaper to replace the unit :(
i say that because you can replace it only "hoping" it fixes it... blah blah.. you see where i'm going?
Sep 15, 2009 | Nintendo Game Boy Advance SP Console
Moving a ref.
do not lay down ,,,, oil from compressor will get into the lines and mess up your system ,,, be safe and haul upright and wait 5 minutes after setting in place to plug it back up / larry
Dec 08, 2008 | Whirlpool ET6WSKXK Top Freezer...
GE HotPoint HSS25 not cooling, but interior lights are on
video on troubleshooting
http://gei.portals.streamos.com/cc/channel.php?emcid=1416&empid=4533&packageid=0000
if after you try the things on the video you may have to replace the motherboard. you can reset the frige by unplugin the power and pluging it back in. If you decide not to replace the motherboard as the unit will work fine untill you press the dispencer i reccomend unplugging the dispenser unit at the top of the freezer door so the frige will not accidently shut down just unplug the connector leading down the door. your frige will work fine without this connection just no water or ice at the door. If your frige is still under waranty (1year parts& labor) call them up and they will fix it.
The motherboard on this frige seems to be sensitive to surges and the transformer for the ice/water dispensencer goes bad. repacing the motherboard corrects this problem they cost about $75 to $90 on the appliance websites to install the new one it is very easy and you need to unplug your fridge and pull the metal cover off the back of the unit by removing four screws. the cables are all different size and can not be pluged in wrong the replacement board should come with instructions. to remove the board you may need needle nose pliers to push in the tabbs on the white board standoffs it should take about 10-15 minutes
I have solved this problem by replacing the back board if you have any questions I can help out
Jan 21, 2008 | Hotpoint HSS25GFP Side by Side...
Dometic NDR 1292 Refrigerator Logo
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
