Question about Refrigerators
What is a "AL" indication that sounds an alarm on the Bosch refrigerator?
We have a built refrigerator in our apartment block at Jool suites, Singapore 217811. There were 2 instances when an alarm went off on the refrigerator. The temperature indicator showed the words "AL". And the refrigerator powers off automatically. This happened once when we went on a vacation and came back to find smelly stuff in the fridge and freezer. What do think is the problem and how do we solve the problem.
4 Suggested Answers
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Posted on Sep 17, 2008
kel1guy2002
  • 3740 Answers
SOURCE: I have an fisher and
Hi and welcome to FixYa, I am Kelly
You should enter the diagnostic mode to determin your fault:
Diagnostic Mode
To enter diagnostic modes, press and hold the MENU button
- then press the UP button for 4 seconds. The PC temperature
will be displayed on the LCD. The actual temperature of the PC is
shown. Note Temperatures are shown in Degrees Centigrade.
PC Sensor Temperature ____
- By pressing the Up button once more, this
will indicate the FC sensor temperature. Note: The "min" indicates minus 12°C
FC Sensor Temperature
- By pressing the Up button once more, this will indicate the Defrost sensor temperature.
Defrost Sensor Temperature
- By pressing the Up button once more, this will indicate the input/Output Status.
Input/Output Status
- Press UP one and two more time, both LCDs display 87.5 but should be ignored
Spare/ Blanks
- Press UP one more time and fault history will be shown.
Fault History
To exit diagnostic mode press MENU button
FAULT CODES:
A wrench symbol and LCD fault code will appear automatically if there is a fault in the
temperature measuring system, defrost system, fans or low ambient heater.
When the PC door is opened an alarm will sound, the number of beeps also indicates
the fault code. Pressing any of the control buttons can deactivate these alarms
Fault Code 1
Reason: On last power up, the power module failed self test.
Primary Action: Replace power module
Fault Code 2
Reason: The previous 2 defrosts were aborted after 30 minutes
Primary Action: Check defrost element
Fault Code 3
Reason: The resistance of all the temperature sensors is outside the normal range
(>45K Ohms)
Primary Action: Check 6 -way Rast connector at power module
Fault Code 4
Fault Code 5
Reason: The resistance of the FC sensors is outside the normal range (>45K Ohms)
Primary Action: Check sensor connector at power module
Fault Code 6
Fault Code 7
Reason: The resistance of the Defrost sensor is outside the normal range (>45K Ohms)
Fault Code 8
Fault Code 9
Reason: The resistance of the PC sensors is outside the normal range (>45K Ohms)
Fault Code 10
Fault Code 11
Reason: The current for the LAH, PC &FC Fan is lower than expected
Primary Action: Check the 6 way fan/LAH, connector at module.
Fault Code 12
Reason: The current for the LAH, PC &FC Fan is higher than expected
Fault Code 13
Reason: LAH is drawing less current than expected.
Primary Action: LAH open circuit
Fault Code 14
Reason: LAH is drawing higher current than expected.
Primary Action: Check wiring connection
Fault Code 15
Reason: PC fan is drawing less current than expected.
Primary Action: PC fan open circuit
Fault Code 16
Reason: PC fan is drawing higher than expected current
Primary Action: Check fan wiring or connections
Fault Code 17
Reason: FC fan is drawing less current than expected.
Primary Action: FC fan open circuit
Fault Code 18
Reason: FC fan is drawing higher current than expected.
Primary Action: Check FC fan & wiring circuit
There are also Ice maker faults that are NOT included above. This should get you started and if everything passes above diagnosis the problem is most likely in your ice maker circuit. The reason I did not include ice maker faults is because they do not cause alarms.
Thanks for choosing FixYa,
Kelly
Posted on Mar 15, 2011
  • 11800 Answers
SOURCE: freezer temperature is 3 Celsius,
The freezer should always be below -10C - if it goes beyond that the warning light will go on; if it goes above 0C the alarm will go off because the food will start to spoil. In your case it appears that the freezer side of your unit is not working and you must find out why.
Start by checking if the compressor works. If it doesn't then do some testing. First find out if the controls of the freezer have an effect: turn the thermostat to the max and push the quick freeze button. If the compressor doesn't starts then either the control board with the thermostat or the compressor itself have failed. Then to find out which just power the compressor directly from the mains - if it starts it's the board, if it doesn't then it's it.
If the compressor turns but the freezer isn't getting cooler then the freon circuit got a leak - it will have to be found, soldered shut and the circuit refilled with freon.
All of this requires experience and the correct tools. i think it's time to call a repairman.
Posted on Jul 04, 2011
What are the Important Factors to look out Buying Your Dream Home ?
1. Location
2. Location
3. Location
4........price
5..... amenities..
I had my dream home built to my spec's and what I WANTED!!
Jun 19, 2017 | The Computers & Internet
Where can I buy a 4 bedroom apartment in Singapore?
If you are looking for best apartments in Singapore then Martin Modern will be the best option for you. They are providing the best and affordable floor plans in Singapore with all the facilities of a condo.
I m having well and good experience of living there. They are providing me outdoor work services, which saves my time. There I m experiencing a luxurious life style with lots of facilities. So, I will suggest you to once think of it before making any decision.
May 04, 2017 | Cars & Trucks
Electrolux door alarm Won't stop. We open door to turn off alarm. Temp seems right but slight condensation at the very top of the fridge. Need to at least disable alarm until I can get a repair.
Check the back wall of the freezer, I would suspect the beginnings of or a full-on defrost failure... If there is frost on the back wall of the freezer it means the evaporator is blocked, disallowing airflow to the fridge compartment... Electrolux Refrigerator Defrost Thermostat 216731001 . If there is no blockage, but temps are still not cold enough, your Frigidaire may be leaking refrigerant...
Jul 03, 2016 | Electrolux ICON Professional E32AR75JPS...
Will I be able to update content myself in Singapore?
Your website will be built using a Content Management system which is a tool that makes it easy for you to update your own website, anytime, anywhere. With basic computer skills, you will be able to add and edit text, images, blog posts or products. All you need is an internet connection and a web browser.here is one web design singapore company.
Singapore Web Design Development Company Singapore
Feb 22, 2016 | Computers & Internet
My freezer has had ice built up on the bottom shelve for about a year now. It leaks once in awhile, what can I do?
The power cut may have damaged the compressor. If it overheated trying to restart it may just click on and off for a while. Check if the compressor is hot and running.
Jul 11, 2015 | Bosch B22CS80SNS (220 cu ft) Side by Side...
I have two Bosch fridges. I just bought this house and there is nothing in either fridge. Worked day we took possession of home, but both stopped working. They have power just won't cool.
Bosch is a high end manufacturer of appliances. Occasionally things can go wrong, such as fluctuations in temperature. Bosch's policy is to charge for calls to customer service advice, even when the appliance is still under warranty, so it's worth trying these troubleshooting steps before making the call. Bosch refrigerators also have an appliance self-test which you can run.
Instructions
    • 1 Check that the plug is inserted into the household power outlet at the wall. If there's no text displayed on the display panel, it is because there is no power to the fridge.
    • 2 Make sure that the door hasn't been left open if the warning signal sounds. The warning signal means the temperature is rising, and frozen food can be at risk. Visually inspect that the ventilation openings aren't covered by household objects, debris or dirt. Press the "Alarm Off" button to switch off the alarm.
  • 3 Ensure that the temperature controls are set correctly if the fridge or freezer compartments get too cold.
  • 4 Check that the water supply is on if the ice-maker isn't producing ice. Test the water supply by using the water dispenser on the door. If "IWD Off" is displayed on the panel, the ice and water are supplies are off and need to be turned on again.
  • 5 Press the "Condensation Heating" switch near the ice dispenser and water outlet on the door if condensation forms on the outside of the refrigerator. If the environment around the refrigerator is too humid, the appliance can compensate for that.
  • 6 Run the self-test program to identify major faults. Switch the refrigerator off and wait five minutes. Switch the refrigerator on again. Press the "Select" and "Options" buttons at the same time for five seconds. The self-test will commence. Keep an eye on the display. "E" indicates a fault which needs reporting to customer service. The number in the US is 1-800-944-2904.
  • http://www.ehow.com/how_5769746_troubleshoot-bosch-refrigerators.html
  • Nov 27, 2014 | Refrigerators
    Find the beeping sound from low battery?
    If your alarm panel is not indicating a problem with a zone, like "check" or trouble, probably not. There are many devices in our homes that can beep periodically (motions are not one of them). I recommend using a piece of tape to temporarily block the hole(s) where sound comes out 1 device at a time, removing the tape if it's not the right one, until you hear the sound become muffled. This is the problem device. Also look for other indicators, such as flashing lights, etc. Likely devices range from built-in smoke alarms, built-in or plug-in CO detectors, septic tank alarms, sump pump battery back-up systems, water softeners, UPS or surge protection power devices, etc. Hope this helps.
    Oct 06, 2014 | Home
    I have a phs8905 sharp watch and I can't figure out what AL is I think it's alarm but it doesnt effect anything. The bell symbol turns the alarm on and off but I can turn both the AL symbol and the bell...
    A is for ALARM, when you want an alarm to sound just set the time you want to be woken or reminded of something then turn alarm on, an alarm will then sound at the time you set
    Mar 02, 2018 | Watches
    Refrigerators Logo
    197 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
