Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Lawn tractor only runs when i spray engine starter in carb, then it stops
Bypass the filter. If it runs with the gas tank hooked strait to the carb., you'll know you've a clogged fuel filter. If this doesn't work, try cleaning the carb. It's not that complicated and doesn't have that many parts.
Posted on Jun 23, 2009
Simplicity lawn tractor
only 2 things can go wrong to stop engine firing SPARK or FUEL you need ample amounts of both. if missing one of either no go
Sep 23, 2013 | Garden
float or float valve sticking in seat.
Aug 23, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cub Cadet has gas, has spark, has air -still won't start/run
Are you pulling the plug to check for wetness after cranking it a few times, WITHOUT using the starting fluid? Also, I would recommend using carb cleaner in place of the starting fluid. Starting fluid runs the engine VERY hot for a brief time and can possibly damage rings, valves, and aluminum parts.
Jun 09, 2013 | Garden
Craftsman lawn tractor will not start!
see if the solenoid on the bottom of the carb is getting power and if so is the valve opening
May 14, 2012 | Garden
Engine runs for 20 seconds then stops.
I have no clue as to the actual solution, but what I would do is disassemble the carb and clean it out. Had a similar issue with a honda motor; ended up buying a new carb off an auction online for $45. Take lots of pics as you remove stuff or find an online parts catalog with a parts blowout diagram.
May 26, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Why would my troy buit lawn tractor sputter and
The tractor is bogging down under load, which can be due to a dirty carburetor or carb out of adjustment or it may just need a general tune up. Before you start tearing things apart, try some carb cleaner poured in the gas tank, and spray some carb cleaner down throat of carb. Check air cleaner and spark plug. Spray all linkages, connecting points, etc on the carb and engine to clean away any gunk.
Jul 23, 2009 | Garden
Craftsman 24Hp Lawn tractor engine dying out
1. check the oil level... don't want the auto shut off to be the problem due to low oil level
2. pull the carb bowl and check for residue. Spray out the needle valve in the carb, spray out the bowl and any jet openings you can find...spray them out too.
3.When you winterized, did you put fuel stabilizer in the tank? If not, drain the tank and refill with fresh...
4. check the air filter element and make sure it is clean...
let me know how it goes...
k
May 31, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
The electric Starter motor will not stop running
If the starter continues to spin after the engine is started..replace the key switch, it is bad
Apr 10, 2009 | Garden
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
111 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
