Question about Gestetner C7417 Laser Printer
Sc 441 it shows that messege after warming up, and then it doesn't work,even after turning the power off and on?
Error 441 mp 4000
SC 441 Trans/development motor error - check for binding/overload on motor -Carl
Feb 25, 2015 | Ricoh Office Equipment & Supplies
Error sc 441 mp4000
Feb 25, 2015 | Office Equipment & Supplies
Repair error 441 in cl3500dn printer
SC 441 - development motor lock.Possible causes:
too much load on the drive mechanism
development motor defective
poor drum motor connector connection
interface board defective
Feb 03, 2013 | Ricoh Aficio CL3500N Laser Printer
SC 441 power off
call for a ricoh service representative to troubleshoot this it is a transfer or charge bias leak, it could be caused by a bad pcu or developer unit or transfer assy.
good luck
Jul 06, 2009 | Ricoh Office Equipment & Supplies
My printer flashes alert CS 441 off on. Can you tell me what's wrong?
The SC 441 is a color pcu motor lock. One of the waste toner augers is clogged with waste toner not letting the drum turn. The only real fix is to replace the color pcu unit. If you could get the auger and drum out it might be possible to free it up, but you will probably damage the drum in the process.
Apr 15, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Alert, Richo Aficio CL 3500N
I have run into this several times with these printers. In every case, it has been the CMY PCU. These run about $300.
I have read that by cleaning the PCU, you can get it to work sometimes. So far, I have not been lucky enough for it to work.
Mar 03, 2009 | Ricoh Aficio CL3500N Laser Printer
SC 441 Error code
Transfer belt cleaning unit.
open top cover, cleaning unit cover(2 black tabs rear)
pull unit slowly. check if paper jam or gears not turning
Dec 24, 2008 | Ricoh CL1000N Laser Printer
SC 441
Hi there the following is the description from the service manual hope this helps you Thanks J
441 PCU (CMY) motor error
The drive motor of the CMY
PCU is not locked.
• Defective gear
• Voltage between pins 2 and 14 (CN12 on engine
control board) abnormal (not +24V), or pin 12
(CN12 on engine control board) unable to send
motor clock
• Defective CMY PCU drive motor
1. Replace the CMY PCU.
2. Replace the engine control board.
3. Replace the main drive unit assembly.
I would try replacing the CMY PCU (Drums (Photo Conductor Units) first before any of the others.
Thanks J
Jan 06, 2008 | Ricoh Aficio CL2000 Laser Printer
Gestetner C7417 Laser Printer Logo
16 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
CheckitRight
CheckitRight
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
