Fan won't turn on outside unit but has a hum noise to the unit -replaced fan motor but did not help at all. The unit is a Goodman Model #CK-361A
  • 55 Answers
Sounds like a capcitor is bad they cost around 10 to 30 bucks
Posted on Aug 13, 2009
  • 43 Answers
Be sure you have power, 220VAC to unit. You may have blown fises or tripped circuit breaker.
Posted on Jun 23, 2009
Goodman troubleshooting
which fan inside or outside hum sounds like compressor is running if outside fan try moving fan blade probably find it dragging or cant move bad motor
Sep 08, 2014 | Heating & Cooling
My goodman unit (1994) makes the loud noise, like a buzzing noise. The unit works, the blower blows air into the house, the air is cold, but the outside fan that blows across the condenser piping isn'
you need to replace your condensing fan motor. the noise you are hearing is the compressor working against a lot of pressure because the heat is building up in you condensing unit. Prolonged operation without an operating condensing fan motor will cause your compressor to burn up, and then you will have the cost of a compressor changeout to the cost of a condensing fan motor.
Jul 06, 2014 | Goodman CLQ36AR49 Air Conditioner
I have an older amana central ac/heating unit, fan not turning outside, did pencil test, turns slowly then stops. changed capacitor a month or so ago all was fine. started making a humming noise so ran and...
Sounds like the fan motor has reached its endpoint. It will have to be removed and replaced. Find the dircuit breaker in your electric panel that supplies power to the air conditioner unit. When you have found the right one, even the humming sounds will be absent. The fan usually is at the top of the unit. You must have opened this to change the capacitor. Remove the fan band motor as a unit and take it to a store like Grangers and determine if they have a motor that would replace the one from your unit. If the motor has a model number on it, you may find a replacement available onlilne by Googling that number and the name Amana. Put electricians tape over the wires that led to the motor, just in case someone turns on the circuit breaker before you have completed the job
Oct 04, 2013 | Goodman CLQ36AR49 Air Conditioner
Goodman model CLJ30-1D humming but not cooling? Help it's 9pm and 100 degrees outside
Hello, so both the fan and compressor were not running? Sound like the capacitor is bad, usually when the temp gets that hot the capacitor overheats and goes bad. The capacitor is located in the outdoor unit inside the control panel, it looks like a round or oval can with wires connected to it.
Jun 27, 2012 | Goodman Heating & Cooling
CKJ-361A GOODMAN CONDENCER UNIT (13 YEARS OLD): RESET INSIDE BREAKER, WENT TO UNIT, NO SPIN-HUM ONLY, GAVE FAN BLADE A COUPLE OF SPINS=STARTED WORKING, RAN FOR APPX. 30-45 MIN, STOPPED, TRIED BLADE...
Replace the capacitor inside the control panel on the outside unit. The top of the capacitor may be puffed up.
The fan motor may also be going bad. Change the capacitor first. It will have to be changed anyway if the motor is bad.
Aug 21, 2011 | Heating & Cooling
Lennox central air for home not kicking on. Fan on the outside not spinning but motor is making a humming noise. No cold air coming in home. We have circuit breakers they are turn to the on position. ...
Is the indoor fan working? The problem with the outdoor fan sounds like it could be your capacitor. Turn off the power to the outdoor unit and make sure the fan turns freely using a screwdriver or something that will reach the blades. If it turns freely then it is probably the capacitor. Let me know what you find.
Aug 25, 2010 | Goodman CLT36AER36 Air Conditioner
Goodman cpl-j42-1a a/c unit, fan on outside unit not working, inside there is cool (not cold) coming out of vent..
sounds like you have a bad fan motor in outdoor unit or a bad run capacitor ck cap first you can go 1 size larger than listed on motor data plate
Jun 10, 2010 | Goodman CKL42AR42 Air Conditioner
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Fan on the outside unit is not running
Fan motor is dry or going bad try to lubricate it and see if that frees it up. If not you will need to get a new fan motor.
Oct 09, 2009 | Goodman CKL36AR36 Air Conditioner
My air conditioner fan is broken, i think.
Fan may need a new start capacitor. It appears or sounds like the motor is not getting the puwe it needs I don'y know what "not fast enough" is to youm but those fans really dont turn very fast, There should be two fuses in a box near the outside unit/ One can bbe bad causing low power to unit. To ck the, There should be something on the fuaw to indicate it's blown. WARNING!! dO NOT TRY REMOVING WITHOUT TURNING OFF ALL POWER AT THE MAIN HOUSE SUPPLY CIRCUIT BREAKER, hIGH VOLTAGE CAN AND WILL, GIVEN THE CHANCE. iF IN DOUBT, CLL OUT A QUALIFIED SERVICE COMPANY.
May 25, 2009 | Goodman CKL24AR24 Air Conditioner
Heating & Cooling Logo
1,000 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
