Question about Earthwise PW01850 1850 PSI Pressure Washer
NO water pressure turns itself off
After hooking up properly you get about 2 seconds of water under pressure. Then shuts down. This is new out of the box.
What is this problem - Karcher 3.86 electric pressure washer: humming noise, plug gets very hot, then unit shuts down?
Your pressure washer is either not fitted with a run/stop device in which case like mine you have to switch off within a few seconds of closing the trigger. Check your model features?
The humming noise is the motor stalled out against the pump because there is nowhere for the water to go. The shutoff is caused by the safety overload switching off after overheat.
Or, it has a pressure operated run/stop which is not working. Because water and electricity don't mix, I would suggest getting more specific help. You can download Karcher manuals /spares lists online from Karcher specialists but remember electricity is the silent killer.
May 20, 2014 | Karcher Garden
My pentair 2 hp challenger pump turns off after 4 second
since it's a new install is voltage set correct on motor ? this seems possible due to short run time you report
May 04, 2014 | Pentair 2 hp Challenger Pump
Chevy astro starts but wont run
Your starter relay is bad. It is under the hook in the fuse box. Look under the cover and it will tell you just which one it is. Replace it with a new one.
Dec 01, 2012 | 2000 Chevrolet Astro
My 1/2 hp mastercraft pump cycles ever 3 seconds roughly. The pressure switch is set at 40-60psi. Should I replace or upgrade my pressure tank?
You might want to make sure you have proper air volume in pressure tank.
Shut down system. Drain tank. Fill tank with air via Shrader valve on top of tank until it has a few less psi than the low cut off setting. This will ensure that the tank still has water in it with some pressure still pushing it out when the pump kicks back on.
Without that cushion of air, the pump short cycles. ie every 3 seconds.....
http://www.pumpsandtanks.com/faq_page.htm#air
Aug 12, 2012 | Plumbing
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
I need to find the ecu relay for an 86 Nissan 300zx.
The ecu is probably under the passenger seat. The battery also has a fusible link which may be blown. Also follow the battery wiring to the regulator box. This may also be faulty
Jun 30, 2009 | 1989 Nissan 300ZX
CAR KEEP CUTTING OFF
Ignition key needs programing or its faulty.A
faulty Key disarms the immobilizer for about 2 seconds then shuts down the engine
Jun 12, 2009 | 1994 Chevrolet Caprice Classic
Sprinkler out put pressure up and down
you say it sounds like air? air passing through a pump that also has a flow of water typically souds like bb's are passing trough the pump...if this is what you are hearing you may have a bad/cracked suction line or collapsed/dried up well..no way to know for sure without actually being there. otherwise adjust pressure switch to a higher shut off. or look for a bad valve. if a valve is not opening all the way it restricts flow hence it uses less water creating a cycling effect.best if you can hook a pressure gauge to the faucet to check pressure.
Apr 12, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Whilrlpool washer error F09
Check the drain hose and make sure it is not plugged or inked. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU) Check/Clean Drain Pump Filter of foreign objects Check for Drain Pump Failure Check the Inlet Valve for proper shut off Check the Pressure switch for proper operation
Apr 07, 2008 | Washing Machines
Earthwise PW01850 1850 PSI Pressure Washer Logo
43 people viewed this question
Top Earthwise Garden Experts
Steve Sweetleaf
Steve Sweetleaf
sirenpete
Level 1 Expert
Call Bill
Call Bill
Are you an Earthwise Garden Expert? Answer questions, earn points and help others
