Question about HP Compaq Presario CQ50-211NR Notebook
Compaq persario CQ50-211NR
Screen wont turn on .the hard drive runs but no screen
I have the same problem. Right now, I suspect an overheated GPU. When I try toboot, I get normal led displays (power, hardrive activity) and the dvd drive spins. However, I get no display. The backlight comes on, but no display. Also, no video out to vga or hdmi devices. After testing the ram, I did some more research.
I found the following results: *HP (aka compaq) devices are notorious for overheating. *low grade solder used on the gpu (less lead content = lower melthing temps) *poor heat distribution engineering on the gpu
What is happening is that the computer is overheating, melting the on board gpu chip and breaking its circuitry.
One fix that I've seen in other HPs is to reheat the gpu to melt the solder and hope for the best. See this link for a video demo (http://www.youtube.com/watch?v=ctHTF3oNdxI)
I almost went through with this procedure for our laptop model, but didn't go through with it because of the surface mounted micro circuitry near the gpu.
Best of luck, I'll let you know if I actually go through with the procedure and what happens~
Posted on Jun 27, 2010
    President:
  • 1,383 Answers
Ok
wHen you power up the copmputer press F8 key then enter in enable vga mode then go to dispaly property and change screen resolution to 1024*768 then apoply and ok.
Posted on Jun 23, 2009
  • kishor
    kishor Jul 15, 2009
    Sir can please rate my solution as Thanks for try?
2 Suggested Answers
sagarkanswal
  • 68 Answers
SOURCE: the screen of my compaq persario CQ50-211Nr laptop
Pls change your laptop screen
My Toshiba NB500 wont boot and the screen wont work. I turned it on this morning and it came up with pxe media failure check cable or something along those line now i try to turn it on and nothing happens...
The Hard disk drive was not detected by the system. Turn off the laptop and try to reinsert the hard disk. Start the PC up and go to Bios/Cmos set up by hitting the F2/Del key.. check if the hard disk drive is in first boot set in boot priority device at ADVANCED settings. then exit and save settings.
Aug 16, 2014 | Computers & Internet
Macbook fan is running and it has a white screen wont start
I would suspect a hard drive or system failure. Try stating up from your system installation disk and running Disk Utilities on your hard drive.
Oct 24, 2012 | Apple MacBook Mac Notebook
My verbatim mediastation 1tb hd dvr wont run, the system will turn on and the start up screen displays for a while but it wont progress any further and then the screen goes blank before reappearing with...
sounds like PSU problem with a 1 terra byte hard drive it uses alot of power to boot up you should get yourself a new HEAVY DUTY PSU with plenty of wattage you can bid & win one Ebay $30
Jul 18, 2010 | Computers & Internet
Not loading up
The hard drive may have came loose if you turn the laptop upside down and remove the hard drive cover usualy has a small picture or imprint like a stack of cds to let you know what one is the hard drive cover once removed make sure hard drive is pushed in properly then retry laptop if this fails they may have killed the hard drive in which case buy another one and replace it
Nov 24, 2009 | Acer Aspire 5000 Notebook
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
Laptop screen wont work.
Assuming you don't have 2 drives installed in your laptop then you will need to get a windows system disk or install disk and boot up with this in the laptop to load windows whatever into your hard drive and set your laptop up to run on the new drive. Here is Microsoft's tutorial on how to install and set up windows:http://www.microsoft.com/windowsxp/using/setup/winxp/default.mspx
Hope this helps you.
Mar 29, 2009 | Acer Aspire 5315 Notebook
HD fan keeps coming on every 30 seconds and runs for 15.
This is no problem, its just keeping it cool,
if you wanted to you could take the hard drive out and give it a clean it wont damage it
Feb 16, 2009 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
System wont boot
i would slave the drive into another system revmove the data off it that i want to keep and then repartishion the drive and do a fresh install.
regards, daniel
Jan 12, 2009 | Abit IC7-G Motherboard
? on the screen, wont turn on
usualy its hard drive issue. find your dvd and boot from dvd (if you restart hold down c key) there you can access disk utility from utility menu and check hard drive.
Dec 23, 2008 | Apple MacBook Laptop Computer Mac...
HP Compaq Presario CQ50-211NR Notebook Logo
238 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
