Question about Garden
Why does my old ariens snow throw stall - Garden
    Genius:
  • 1,406 Answers
Check the gas - be sure it's fresh and clean, and has no water in it.
Check the spark plug - it may be time to replace it.
Posted on Jul 28, 2014
WHY DOES MY ARIENS SNOBLOWER PLOW THROWS THE SNOW BUT ALSO PUSHES IT LOIKE A PLOW?
could be a broken shear pin on the impeller one has to see things like this to diagnose properly
Mar 14, 2017 | Ariens Garden
Have a gravel driveway bought a Ariens 24 Snow Thro adjusted skid shoes to lift machine, is the scraper blade also adjustable, it is throwing a lot of rocks?
Yes, they are all adjustable. Loosen the hardware, Find something to use as a shim... a few paint can stirrers.. put them under the Scraper to lift it about 3/8" then tighten the hardware. See how that helps the stone throwing. Gravel driveways are tough for Blowers and Plows...It's best to actually leave snow on the driveway to pack down and form a Base. Then the next snow will be stone free.
Jan 07, 2017 | Garden
My Ariens 5520 won't throw snow more than 3-4 feet. How do I get it to throw snow like it used to.
only a guess mind you but it possibly has a sheared pin in the blower
Feb 04, 2015 | Garden
Ariens snowblower problems
The snow blower does not throw snow. Snow jams up in the chute
Jan 04, 2014 | Motorcycles
The blower won't throw snow - especially heavy snow. Auger and impeller turn but bog down. Trying to replace belts, but there are no numbers or sizes on them. Are these generally available (say at a...
If the belts are intact, then NAPA or a hardware store should be able to replace them. If they are shredded, then you should order them from Ariens. Good luck!
Feb 01, 2011 | Garden
I have a ariens 24 "sno tech it will not throw
The most common cause of this is the drive belt is worn. If you remove the cover (usually plastic) in the middle of the snow thrower and look at the belt closest to the blower assembly. This is the blower drive belt. (Your operators manual will show you the location and how to remove the cover if you are unfamiliar with your snow blower)
With the engine not running, have someone depress the drive lever and check the belt. You should only be able to depress the long side 1/2 inch or less. More than that the belt has stretched and needs to be replaced. On some older blowers you can adjust the tension pulley, but most made in the last 15 years, you can't.
The belt may be frayed on the edges or glazed causing it to slip (it is shiny on the sides of the belt)
You can get parts (the new belt) through your local Ariens dealer or jackssmallengines.com
Feel free to ask any other questions. I know Snow Blowers. Please remember to rate this answer!
Jan 13, 2011 | Ariens 34 In. Zoom Series Riding Mower
Wheels losing power on Ariens 5520 snowthrower
i would open the bottom access panel and tighten the tension on the drive belt. i had a simailar problem with my 5520, it wasn't my wheel drive, but my thrower. it would throw snow intally, but stop as soon as it got in deep snow. when i opened the panel, i noticed the the tension on the belt was really loose. so i pushed the fly wheel close to the belt and tightened the fly wheel..and VIOLA as good as new. hope that helps...
Feb 10, 2010 | Air Tools & Compressors
Old craftsman snoblwr stalls after 5 min use
More likely the fuel filter either air locked if a bowl or dirty and neds to be replaced for sitting around unused. Itf that doesn't work. remove , dissemble and clean the carburator.
Jan 11, 2009 | Ariens 34 In. Zoom Series Riding Mower
Garden Logo
60 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
