Question about Mini Sport & Outdoor - Others
Motovox mbx10 mini bike fuel mixture - Mini Sport & Outdoor - Others
2 Suggested Answers
MNfisherman
  • 11896 Answers
SOURCE: buddy turned air fuel mixture screw on 5hp mini bike engine
Two screws. One for idle mixture, and one for idle.
Posted on Sep 11, 2009
My 50cc street assassin quad goes on its own when the chock is on, an if I take choke off it conks out? Can anyone help?
Hi, Liz and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Float needle and seat sticking.
5. Float level too low.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
ATV Connection
Fix your Mini bike Carb bogging cutting out etc
Chinese ATV bike carb clean and deregulation of sealed carb 3gp
Feb 14, 2016 | Goes Motorcycles
I have a motovox mvs10 43cc 2hp gas powered scooter and was wondering if there is suppose to be plastic like components in fuel tank and what are reasons that could cause it not to start.
often the is a fuel filter in the tank at the end of the fuel line, if it has deteriorted then yes it could stop it from starting due to a clog in the carb. If ou have good spark then sprat a few puffs of starter fluid into air intake or on the air cleaner ( which should be clean ) . if it starts for a second or two then it's most likely your carb.
Nov 23, 2014 | Motovox MVS10 43cc 2 Hp 2-Stroke...
Why will my motovox mbx10 not get fuel to the engine
Check the fuel line, maybe it's clogged. Also check the fuel filter if you have one.
Aug 17, 2014 | Garden
49 CC STREET SCOOTER TWO STROKE NEED THE GAS TO OIL MIXTURE
the mixture ratio is 50 parts gas to 1 part oil. Use only a good quailty stroke oil, never use motor oil
Nov 01, 2011 | Quad 47 cc / 49 cc Pocket Mini Bike...
I have a 50 cc kazuma atv i know the upper screw is the idle and the lower is the air/fuel mixture, what should the air/fuel mixture be set at, for example, 1 and a half out?
The easiest way to adjust the air fuel is using a RPM capable multimeter. But, in a pinch, a good ear will do just fine. Adjust the screw inward until the rpms drop. Turn it VERY slowly until the rpms return upward. Once you finish, just work the screw back and forth to get it to the point the rpms change (however this is not necessary). Congradulations. You're finished.
Sep 21, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
On a kazuma 50cc engine carb adj screw location
The lower of the 2 screws is the fuel/ air mixture- the upper screw is the idle adjust screw
Jan 22, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Bike has a lag when its cold like its something in the motor is in a bid. after 10 miles or so it frees up and runs like its supposed to
What weight oil are you running in your bike? Years ago when we ran the straight 60 weight oil, on a cold morning you had a time kick starting the bike. Another thing is that when your bike is cold, it requires a much richer mixture to run. Whether your bike is fuel injected or carburated, you're running a very rich mixture. The fuel system control or the enricher provides the rich mixture and a rich mixture will make the bike run sluggishly.
Oct 04, 2009 | 2004 Harley Davidson FXST - FXSTI Softail...
Buddy turned air fuel mixture screw on 5hp mini bike engine
Sep 11, 2009 | Garden
Sport & Outdoor - Others Logo
66 people viewed this question
Top Mini Sport & Outdoor - Others Experts
Bill Eager
Are you a Mini Sport and Outdoor - Other Expert? Answer questions, earn points and help others
