Question about Acer Aspire 5735 Notebook
Windows wont load
When i turn my laptop on i get load up saying " windows fail to start a recent hardware or software change might not be configured incorrectly. if windows files have been damaged or configured incorrect start up repair can help diagnose and fix the problem. if power was interupted at during start choose start windows normally." 2 weeks ago using my laptop normally havent used this since and today went to use it and it wouldnt start up it would stay on loading screen and i havent changed any hardware or software. i have had it since november 2008.
  • doggydoggy_1 Jun 23, 2009
    i cant get past the loading screen.
    it doesnt let me get that option to press F8
  • 47 Answers
It could be or a virus not that i really thinkso or it coul be dirt try too clean it a bit
Posted on Jun 23, 2009
    President:
  • 1,383 Answers
When you power up the computer press F8 key then start it in safe mode.
Then go to control panel -> add remove program then uninstall recently install software of drivers.
Windows fails to start
Is the hard disk, change the hard disk and/or the sata interface wire.
Mar 10, 2012 | Toshiba Computers & Internet
My compaq mini notebook wont boot up, when you switch it on it comes to a page saying windows did not start successfully. A recent hardware or software change may have caused this. It then gives you the...
Hi, sounds to me that you are having a software problem. When you boot the laptop choose the Last know good configuration option to see if that will correct the problem.
Dec 20, 2010 | Compaq Computers & Internet
When computer is turned on it says...windows failed to start.a recent hardware or software change might be the cause..
This is very common error after installing a device that is not supported and not properly installed...
Here is the solution:-
while starting your computer press F8 continuously. You will see a screen listing some options for starting windows like Safe mode, Repair, etc...in that list select the "Last Known Good Configuration" and it will solve your problem...
Hope this will help for sure.....cheers:)
Sep 24, 2010 | Toshiba Satellite A215-S4747 Notebook
WHEN I TURN MY WINDOWS XP ON IT HAS A BLACK SCREEN WITH WHITE WRITING SAYING, WE APPOLOGIZE FOE THIS INCONVENIENCE, , BUT WINDOWS DID NOT START SUCCESSFULLY. A RECENT HARDWARE OR SOFTWARE CHANGE MIGHT...
Try safe mode.
If that works, there is a card or software that has failed.
Checking the cards is easy, take them out one at a time and restart, for motherboard features, shut them down one at a time.
For software, did you load anything new, even updates, if so remove them.
Mine turned out to be a bad PCI card for a scanner.
Feb 18, 2010 | Computers & Internet
Laptop wont even attempt to load windows??
With this kind of problem, you must put in the Windows software disk and boot. Then select repair Windows from the list. This option will attempt to correct the problem.
If you do not have the disc, boot into the repair / diagnostic mode from the boot screen. See if there is an option to create boot disks.
Jan 04, 2010 | Toshiba Satellite A70 Notebook
It wont start up kind of
Try start, run, then type MSCONFIG go to start tab and UNcheck everything, then go to services and at the lower left of the window it says hide microsoft services and check the box then disable all then restart and see if that helps.
Sep 02, 2009 | ASUS Eee PC 1000H Laptop
My dell compaq presario 500 laptop wont go!!
You will need to buy or borrow a windows setup cd and then repair the installation with the windows setup. That should solve the problem.
If you don't own windows you can buy a copy of the version you want to use from
www.ebay.com
Nov 14, 2008 | Compaq Computers & Internet
My presario 500 wont even turn on
try running it in safemode and if you have recently added any new hardware or software that may be causing your problem uninstall it while you are in safemode.
As the computer boots press F8 to enter safe mode. If this is successful then everything on the screen will look big, ignore that for now. uninstall anything that may be causing the problem. If you have not loaded anything lately, then while in safe mode restore your computer to an earlier date when you know that everything was working okay.
You can do this by going to Start>all programs>accessories>system tools>system restore. Then choose a date when you know that things were okay and press restore. You computer will restore to the date you selected and it will reboot. If asked to whether you want to start windows normally after the boot then select that option.
I hope this helps
Nov 14, 2008 | Compaq IDE CD-Rom Drive Presario 500...
Acer Aspire 5735 Notebook Logo
152 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
