Question about Samsung DMR77LHS Tall Tub Dishwasher
Reset Samsung dishwasher
Heavy light keeps flashing and won't do anything else
3 Suggested Answers
  • 3247 Answers
SOURCE: Samsung dishwasher flashing heavy light
Had a look in the user manual for your dishwasher.http://downloadcenter.samsung.com/content/UM/201211/20121101114232459/DW7933LRASR-00141A-02.pdf
Page 26 shows blinking Heavy light means there is leakage in the dishwasher. Most likely there is water in the base under the drain sump which could cause the flood switch to trip. Turn mains power to dishwasher off. Pull it out from under kitchen bench without breaking the hoses. Put some towels on the floor and turn dishwasher back and forth on incline to get water out. Wait a little and turn on. If no difference then you need to dry the base and find the source of the leak. More likely the door seal.
Posted on Apr 03, 2014
ChildShield
  • 120 Answers
Anytime a dishwasher stops mid cycle and blinks, it is usually because of clogged drain port, and safety switch prevents next cycle, so just blinks. You will probably see bottom of tub filled with water, and float switch is preventing next cycle which is calling for more water, and obviously there is not enough room, so shuts down next cycle. Remove as much water as you can with wet vac or turkey baster to suck out water, then try and see if cycle starts.
Remove bottom of tub filter, look for drain hole usually at back of tub and see if it is clogged, usually visible at top of drain. Pretty easy to fix, just clean out the area of food waste or broken piece from glass, another common sudden blockage. If you have wet vac, place it over drain hole and cup your hand around nozzle of vac and hole to creat seal and suction to insure clog isn't in drain hose.
Good luck, FREE-BUSINESSES.com
Posted on Nov 25, 2014
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
I have 3blinking lights on a Samsung dishwasher DW9733LRABB/AA the normal,heavy, and smart auto
Dishwasher Heavy Error Code Repair Samsung - YouTube
? 2:24
https://www.youtube.com/watch?v=uLoj9TpqVRM
Aug 14, 2014 - Uploaded by JoeBrownToolGuy
Dishwasher error code "Heavy" flashing light. Samsung Model DMT400. Video shows what you need to do ...
Nov 23, 2015 | Samsung Dishwashers
Normal, heavy, delicate lights stuck on--cant power on or off
If you have tried to unplug from mains power and there is no difference then you will need to provide the actual model number of your dishwasher in comments field.
The Samsung error codes for Normal, Heavy , Delicate lights stuck is not listed. The closest is Normal, Heavy, Quick which relates to a Low Water level. Also confirm which lights are stuck in your case and whether these are flashing or not.
Apr 17, 2014 | Samsung Dishwashers
Brand new Samsung Dishwasher DW7933LRA Flashing light "HEAVY" and will not start
Apr 03, 2014 | Samsung DMT400RHS Builtin Dishwasher
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
How do I reset a samsung dmt300 dishwasher
i have a samsung DMT300 Series. The heavy light keeps blinking. How do I reset it? It was leaking water and I believe we fixed it. What can I do?
Sep 12, 2012 | Samsung DMT300RFW Builtin Dishwasher
Hi I have a Whirlpool dishwasher ADP5740, Condenser. My grandson pressed the start button before I had set a programme, now the light is stuck on the pre-wash and the start light is flashing and it...
If you have a reset or cancel button try that. Look in your manual for a reset
procedure or troubleshooting section. It is just stuck in a cycle and needs to be reset
or cancelled.
Marty Mouse just a housewife.
Jun 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My samsung dmr77lhs LE light keeps flashing how do i reset this garbage machine? Resetting the power does not work. Please help
I have the same problem with my dmr77. My coffee pot ran over and evidently ran down behind the Samsung dishwasher. It thinks that it is leaking. How do you reset it?
Oct 06, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Flashing clean light
try opening the door and closeing it to aknoldge you know they are clean and is there a lock symble under the green light
Feb 10, 2009 | Kenmore Dishwashers
Samsung DMR77LHS Tall Tub Dishwasher Logo
75 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
