Question about Hampton Bay 24002 Ceiling Fan
138-498 How to change the light bulbs in this fan! I replaced the bulbs through the top. It still doesn't light up. How do you get to the bulb in the bottom?
ceiling-fans
  • 20 Answers
SOURCE: Windworld III has mind of its own -- light comes on any time it likes fan changes speed
This sounds like one of the most common problems with Hampton Bay's remote-contolled fans...either the transmitter (remote control) or the receiver (mounted in the fan, typically inside the ceiling canopy) has gone haywire. A circuit has blown or something is short-circuited, and it has a mind of it's own. The only fix is to replace the receiver and transmitter, which are relatively cheap and sold as a pair at your local Home Depot and Lowes.
Hope that helps! If you ave any other questions, feel free to ask!
Posted on Jun 17, 2008
SOURCE: light bulb socket uses intermediate base bulbs, not standard bulbs
I found the solution on the web. The only place it looks like that has this adapter is voss lighting. Here is a link to the adapter. http://www.vosslighting.com/storefrontB2BWEB/itemdetail.do?action=prepare_detail&itm_id=18159&itm_index=7
Posted on Nov 11, 2008
SOURCE: hampton bay ceiling fan , model # 55295
I had the exact same problem. To solve it, I had a friend hold the area of the fan that the globe screws into. I wore rubber dish gloves to get a good grip and pushed up slightly on the globe as I turned counter-clockwise. My friend held the other part and turned clockwise a little as well. It took a lot of pressure for it to finally come loose and then we just turned it about another 90 degrees and the globe slips right out of the groove.
I couldn't believe how hard this was to do.
Posted on Feb 14, 2009
  • 7 Answers
SOURCE: changing light bulbs in Hampton Bay model AC 527 Ceiling fan
press up while turing it counter!
Posted on Mar 29, 2009
patrick_a_t_
  • 3 Answers
SOURCE: Changing light bulb in ceiling fan
At the top of the pull chain there is a metal piece; this is threaded on a bolt. Unscrew the metal piece and lower the globe to expose the bulbs then remove and replace the bulb(s). I recommend flourescents as they are more economical, run cooler and last linger than incandescents (regular bulbs).
Posted on May 17, 2009
Minks aire mojo ceiling fan light will not come on
Try changing the bulb. Make sure the bulb is touching the connector in the bulb socket.
Aug 15, 2014 | Minka Aire Ceiling Fan
How to change the inside bulb in a ge spacemaker microwave that has a top vent fan
My Spacesaver bulb replaces from the top. You have to remove 2 screws that hold the upper vent cover. W/ cover off you will find a phillips head screw about the center that holds the bulb cover. Remove the cover screw & lift up & remove the cover, then replace the bulb, the cover & screw then put the vent cover & it's 2 screws back. There may be some variance but they are all similar.
Mar 16, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
Light in freezer sometime goes on and other times doesn't. What size bulb do I need? could this be the switch for door closing?
Bulb is a 40 watt appliance bulb, it can be found at any hardware store or walmart. Yes this problem could also be caused by the door switch not operating correctly.
Dec 20, 2010 | GE GSS25JFM Side by Side Refrigerator
How do I change the light bulb and/or night light for my NuTone bathroom Fan-Light Model 8663RP?
The whole cover/grill/globe pulls straight down to expose the bulbs. There are two heavy "V" springs, one opposite the other, that hold the grill to the fan box. You need to overcome the holding power of these two springs to pull the grill down. If necessary, you may want to run around the edge with a sharp knife in the event it was painted in place.
Mar 30, 2010 | Broan-NuTone N-8663RP Combination Light...
How to change a light bulb
At the top of the globe there will be three small screws. Turn them counterclockwise out while holding onto theglobe so that it does not drop. Turn each screw just a few turns unitl the globe slides down and out. Replace the light bulb and then reverse the procedure to replace the globe...
Heatman101
Feb 24, 2010 | Hampton Bay 04345 Cruiser Ceiling Fan
How can I change the light bulb in this fan. The
They have opening clips on the top side all around the cover, you can reach it with your fingers and try opening them all, the cover will come off easily, once done you can unscrew the light bulb and install a new one.
Feb 07, 2010 | Broan-NuTone Broan 110 CFM Premium Bath...
Como Fan MInka Aire light bulb burned out
remove the cover and unscrew the bulb. get a replacement especially designed for a ceiling fan.
Sep 07, 2009 | Minka F603-WH Ceiling Fan
May 17, 2009 | Hampton Bay 24002 Ceiling Fan
Hampton Bay 24002 Ceiling Fan Logo
46 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
