Question about Motorola Mobility H700 Wireless Headset
Add mute switch - Motorola Mobility H700 Wireless Headset
  • Official Brand Answer
  • 1,623 Answers
Have you tried both volume buttons simultaneously while in call? Otherwise your phone probably has a one button option.
Mark
Motorola Support
Posted on Jan 12, 2015
How do I fix channels with no sound
Mute Switch/Mute-Clip LED :
  • This switch mutes all Aux, Group and L/R sends from the corresponding channel.
  • This switch is equipped with a red LED that will illuminate when the channel is muted.
  • When the MUTE button is out,the LED functions as a Clip indicator that will illuminate at 2 dB below clipping.
  • Muting the channel does not prevent the PFL signal from being sent to the PFL/AFL mix when the PFL Switch (12) is in.
  • This switch mutes its respective Group send from the Group channel.
Go to page 11 in this link :
Peavey FX Mixer Series Operating Manual
You can also try, Restoring Factory Settings, in the Utility Menu Options.
Go to page 16 in ths link :
CAUTION:
Restoring the factory settings option resets your mixer's presets, reformatting factory presets and erasing all other user presets. (This option is handy when your venue has permanently changed and all-new presets are required.)
Once confirmed, the presets are not retrievable and will be permanently lost.
Should you select this option in error, a warning screen allows you to cancel the procedure.
Sep 05, 2015 | Peavey 32fx USB 32 Channel Mixer
How do you take it off mute
Are we talking about squelch or mute?
Squelch...menu subset called 'X-TRA', which gives access to squelch settings.
Mute... three-position slider switch is used to power transmitter on/off, and has a middle position, which either acts as mute switch (when you switch from On to Mute) or switches the mic into programming mode if you start from the Off position.
Feb 18, 2013 | AKG SR450 Multichann Diversity Receiver
The mute button cuts the main audio but the effects audio is still heard. What to do?
That's basically normal actually...however it depends on which aux send you're using. If you use aux 1 for the effects, you can use the pre/post switch on the master aux 1 send to switch it to pst fader....now your mute switch should kill the effects as well. Aux 2 is good to use for monitors where you don't need to return them to the mixer.
Mar 25, 2012 | Mackie 1202vlz3 12 Channel Mixer
Where is the ipad mute button cant get any sound fron down loaded war game
The mute switch is on the right side of the iPad. Check your switch settings first:
Tap Settings > General.
Under "Use Side Switch to:", select Lock Rotation or Mute.
Settings > General
Make sure you're using it to mute, and then slide the switch to toggle mute on and off. Also use the volume rocker in case you have the volume set too low.
Nov 03, 2011 | Apple iPad with Wi-Fi + 3G (Choice of...
I have no sound on my hitachi 61swx12b
Howdy;
Try these items first: re-set TV and any type of BOX you have hooked to the TV. 2) Ensure all cables are secure. 3) Make sure that there is not a speaker switch on back of TV. 4) go into customer menu (audio) and make that speakers are turned on. 5)
Symptom: AUDIO MUTE OR HUM.
Cause: Remove ALL jumpers on bottom of SRS pwb.Add 1000mf@16v across CSH1 add 1000mf@16 across CSH4 add gnd wire 24ga from PSU1 conn pin 18 to IT02 pin 97.
Good Luck, Big Irish.
Nov 22, 2009 | Hitachi 61SWX12B 61" Rear Projection...
I'm thinking of buying Logitech USB Desktop Microphone but I want to know if it works well with multiplayer games because that what i would use it for. I haven't been able to find any info on how the mic...
Yes, this mic does work well. Headset usually work the best, but I do know a few people who use this mic for their gaming.
Control and convenience
  • Advanced digital USB: Experience superior sound clarity with the simplicity of a single USB plug-and-play connection.
  • Noise-canceling microphone: Filters out unwanted background noise.
  • Power switch: Illuminates when microphone is active.
  • Adjustable microphone: Pivots on base to hold preferred position.
  • Eight-foot shielded cord: Gives you more desktop flexibility.
  • Mute switch on base: Instant and easy muting.
  • Weighted base: Adds stability.
Technical Specifications
    • Frequency response: 100 Hz–16 kHz
    • Input sensitivity: -67 dBV/µbar, -47 dBV/Pa +/- 4 dB
    • 8-foot shielded cord with USB connector
    • Connector: USB 1.1
YOU CAN GET USER REVIEWS HERE:
http://www.google.com/products/catalog?q=logitech+usb+desktop+mic&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1&ie=UTF-8&cid=16452149199579405298&ei=GyxWSr-ePIrQM7aJvZ0I&sa=X&oi=product_catalog_result&ct=result&resnum=5#ps-sellers
Jul 09, 2009 | Logitech USB Desktop Consumer Microphone
Blinking green light on microphone, headset not working
The blinking light means headset is muted. Un-mute the headset by pushing the small toggle switch on the back of the headset.
You may need to reset the headset. You can do this by first pressing the mute switch on the back of the headset and then simultaneously pressing the call switch on the side of the headset for about 4-5 seconds.
You will need to pair the headset with the base again.
Mar 13, 2009 | Plantronics CS55 Wireless Headset
How to mute and add music to Motion SD STUDIO 1.3E
Motion Studio camcorders will also accept .WAV files. Convert your MP3s and place in same folder as your video files. They will appear in the audio tab. Note that .WAV files are much larger than the canned music that comes with the software. Rod
Dec 26, 2008 | Video Cameras
Convergence settings
Key Functions
7,8,9 = select R, G or B
+100,0,PRE-CH = mute R, G or B
INFO = test/normal
4 = shifts from point to line, grid move
2 = restore factory
SOURCE = H/V select
ADD/DEL = Save
S.MODE = exit
MUTE = cursor forward
P.MODE = cursor back
Volume +/- = moves convergence left or right
Channel +/- = moves convergence up or down
1 = zero's all convergence settings (ugly!)
U/D/L/R = move cursor
SELF FOCUS = saves the convergence adjustment - do before exiting
Good luck.  I let a sub-standard service joint work on mine - they replaced the OEM chips with a higher wattage equivalent, and I've had nothing but problems ever since.
Oct 11, 2007 | Samsung HC-P4752W 47" Rear Projection...
Motorola Mobility H700 Wireless Headset Logo
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
