Question about Konica Minolta Bizhub C353 Copier
How do you copy bank checks with foil security seals?
We used to be able to do this but now when we do, the whole page comes out black. We have called maintenance and they have been out twice without results. In fact they say we were never able to do it, but we have copies of checks with the seal on it from before. Any suggestions/helpful hints would be greatly appreciated.
  • Konica Minolta Master
  • 6,161 Answers
Kevin Hayes
  • 167 Answers
SOURCE: copying
In the driver there are "copy protect" and "Watermark" options.
See if these are on.
Posted on Oct 09, 2008
  • 214 Answers
SOURCE: Double-sided copy output
In print dialogue box there will be a setting for long or short edge binding, associated with duplex printing. Find it and try it. Good Luck.
Posted on Apr 28, 2009
  • 51 Answers
SOURCE: Konica bizhub C351 copier with BLACK area in center of the copy
u have to run the setup for machine if u like i can send u the step guide how to setup the machine
Posted on Aug 30, 2009
Testimonial: "Thank you Daroon for the setup guide you sent to us via email.We will try this tomorrow to see if this resolves the problem. Thanks again, Lee"
anjana03
  • 361 Answers
SOURCE: when I use the copier the copy has dirty spots.
there may be glass in inner side. swipe it by soft cloth orcottan. then u r problem solve . we face same problem in brother copier. (nepal)
Posted on Oct 09, 2009
n25an
  • 622 Answers
SOURCE: I will copy a page with text. The result is 10%
check all your plugs... and connections.... broken plugs or connectors can cause issues... clean the copier... clean the optics... with a clean cloth... then make a copy... if not good... then make an internal printout...like a status report... if good... then the problem is in your optics... clean optics... blow stuff out with an air can... clean mirrors... if bad then check your drum and fuser... check for problems... try matching marks... then clean your ccd... generally this is a very thin piece of plastic that acts like a laser... sometimes it gets dirty... if still unable to fix... at this point I would call a service technician
Posted on Mar 14, 2010
Gvalidate questins
You are using an older version of the browser, which may not have the right encryption abilities. Download the latest copy of Firefox/Chrome browsers and try from there.
You also may have some Security settings in the browser rejecting the secure page.Change these to Default Medium
Dec 28, 2013 | Computers & Internet
Black spots on each page
A laser printer has its rollers (which I believe you said you cleaned...very important) and the cartridge you put in the printer has rollers too! Carefully check them and the wiper on the cartridge. If all of those things are clean, then you should get clean copy!
Jan 11, 2013 | Dell 3130cn Color Laser Printer
SOLID BLACK LINE FROM LEAD EDGE TO TRAIL EDGE
"dk" means the the life black drum is over. You need to replaced the drum and blade. Or you can replaced the whole drum cartridge. The line that you are getting from one of the blades, more likely from the black drum. Pull out all the drum check if there is toner on the drums.
Mar 20, 2009 | Sharp AR-BC320 All-In-One Led Printer
White line and very, very dirty copies
the nealy black copies sounds like the drum is going, try adjusting the exposure to light, if it comes out with the whole page the same way but just lighter than change drum. White line sounds like there is something on the coronas.
Jul 22, 2008 | Canon PC-940 Black and White Copier
HP J5780 All in one printer
Once try to make a scan and if we are getting line even while scanning. Then perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01129408&cc=us&lc=en&dlc=en&product=3301296
Directly go to step three and then try to make a copy.
If the issue still persists then power cycle the all-in-one.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Now try to make a copy and check for the result. If the issue still persists then reset the all-in-one.
  1. Unplug the power cord from the product.
  2. Press and hold # and 6 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
Jun 05, 2008 | HP Officejet J5780 All-In-One InkJet...
Image classD661 blank copy
If you just changed the toner cartridge, you probably forgot to remove the metal foil seal, from the side of the new toner cartridge.
Dec 07, 2007 | Canon imageCLASS D661 Digital Printer
Copying and scanning problem
The tech support at HP said its a hardware issue, especially if the following test results in a black page:
1) Open cover
2) Push scan button
if the bulb doesn't come on or the page is still black its a hardware issue.
Nov 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Konica Minolta Bizhub C353 Copier Logo
372 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
