Question about Microwave Ovens
Microwave does not heat, how can I fix?
HI, Powerpoint PP900INT Seems to be working fine, but does not heat the contents. About 7 years old. Tried leaving it unplugged for a day! Since it is integrated into the kitchen, I woul rather not replace it. Since I am broke, I would rather not replace it. Since I was an engineer, there may be something I could do, so having a look online for similar experiences. Regards Robert
MicrowaveSvc
  • 9098 Answers
SOURCE: Cannot heat
Sounds like it overheated, tripped the thermostat, then the thermostat reset. Chances are you have a bad magnetron. GE may have a campaign (not a "recall", mind you!) to offer free replacements if yours is a model that has a known history of problems with the magnetrons. I would call GE and ask them about that. *grin* GE Answer Center 1-800-626-2005 24 hours a day, 365 days a year
Posted on Dec 14, 2006
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave stopped heating!
This may have already been dealt with, but others can benefit from an accurate, thoughtful reply to this problem.
Concerning the problem Guest is having with the fan coming on when the door is open.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Concerning the original problem of no heating:
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Posted on Nov 26, 2007
SOURCE: Microwave troubleshooting...
My GE spacesaver microwave all of a sudden stopped heating up things. The lights, fan, turntable, etc. work, but nothing is heating up. Any suggestions?
Posted on Dec 26, 2008
EwingElect
  • 276 Answers
SOURCE: GE Microwave won't heat or cook - one year old
More than likely the magnetron has failed. This could be for a number of reason. Do you use your microwave to heat wheat packs or warm plates? If so, you may have dried the magnetron out (they use the moisture in whatever you're cooking to heat it, and plates/wheat bags have no moisture).
I'd say a trip to your local Microwave repairer could be in order. It could also be the High Voltage Fuse which has failed. Either way a repairer will be able to tell you!
Posted on Mar 25, 2009
garing
  • 998 Answers
SOURCE: Microwave Totally stopped - nothing turns on HELP Needed
check fuse
Posted on Aug 08, 2009
It's heating but not cooking food can it b fixed?
If you mean it's running, but not heating food, then the problem is most likely in the high voltage circuit, or whatever powers it (typically a relay). The most common item to fail is the high voltage rectifier. If it's more tha 7 years old, or has been used frequently to heat low water content items (popcorn), then a defective magnetron could also be the problem.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
Jul 20, 2016 | Microwave Ovens
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
Problem with Samsung microwave oven
My Samsung microwave is about 7 years old and everything works fine except it won't heat the food. What can we do to fix it?
Nov 24, 2012 | Microwave Ovens
Microwave will not heat
The problem is the magnetron, "heart of the microwave oven" or the inverter board if 7 years old or less.
Apr 19, 2012 | GE Spacemaker Over-the-Range Microwave
We have power and door fits snugly but the oven does not heat up. Have tried Reset button but no luck. Microwave is 7 years old.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Feb 06, 2011 | Panasonic NN-S541 Microwave Oven
I have the FMV145 Over-the-Range Microwave. I
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Mar 01, 2010 | Frigidaire FMV145K Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Smeg Microwave SA-971C2
the door protection circuit needs attention, the door catches operate microswitches, but there is also a third which is a crowbar microswitch. if all three do not operate in the correct sequence then the safety switch or fuse will go.
Feb 18, 2009 | Smeg FMC24 850 Watts Convection /...
Re: microwave does not heat
Is very unlikely that there could be any other electrical failure since everything else seems to be working.
If you are able to fix it yourself then is way more cheaper just to buy the magnetron.
Click here to find the magnetron.
Before you do any work on this device, please click here to know how to discharge the high voltage capacitor and other safety concerns when working with devices that generate high voltages.
I would say is not worth it to spend more then $100.00 for a 5+ years old microwave.
Good Luck.
Jul 16, 2008 | Whirlpool MH6150XM Microwave Oven
Microwave Ovens Logo
89 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
