Question about TPC Mirage Patient Dental Chair TPC
Tpc back fuse dead? - TPC Mirage Patient Dental Chair TPC
Ineed a turntable belt for tpc-hd 12
Fixya is not a buying service. Try an internet search for turntable belts.
Oct 17, 2016 | Audio Players & Recorders
Why does my car idle at 2500rpms
CHECK IF ANYTHING GOT STACK,CLEAN THROTTLE BODY.CHECK ALL CONNECTION,YOU COULD BET THE PINS!
May 21, 2016 | Cars & Trucks
Thomas radio tpc-767 o/CH won't turn on. Plugged in turned on, heard pop and now won't turn on, looked for a fuse to pop but can't find anything, what should I do?
Sounds like a wire might be exposed and shorted out the radio. Could be a bad capacitor, but if you can open it up you should be able to see a burnt spot on a circuit board.
Mar 09, 2015 | Cars & Trucks
Thomas pacconi # tpc-mse-800-o (no power)why is there no power getting through hole unit?
Since you have no sound even on radio, it's not going to be a bad tt motor. There is no fuse except for a thermal fuse inside power transformer. I would start with a continuity check accross both of the blades on the plug. If it's open, you prob have a bad power transformer.
Sep 06, 2014 | Seth Thomas Pacconi Turntable
Thomas Pacconi TPC-MSE 800
could you include a picture of the under side of the turn table where the belt is fitted?
May 21, 2014 | Seth Thomas Pacconi Turntable
Why would my rpm jump and make my car seem to jolt forward? i was told it could be the camshaft sensor,or the throttle position sensor...any suggestions?
The TPC ( throttle position control) or the IAC (Idle Air Control) is defective. The TPC is bolted on behind throttle control. Takes very small hands to remove it. Symtoms are the engine will speed up to ~ 2000 or more RPM when the gas peddle is released. Almost like the Toyota problem. But you can apply the brakes to slow it down or stop.
Jan 10, 2011 | 2001 Oldsmobile Alero
How do you turn off BMW X5 tire pressure light once the tires have been inflated
On some X5's you can do it through the instrument cluster whereas other through the button on the centre console depending on the spec.
On the centre console you'll find the tpc button. It looks like a flat tyre with an exclamation. With the ignition turned off, press and hold this button and turn on the ignition to position 2. You'll notice on the instrument cluster the light go red, yellow, off and then come back on yellow. When the light comes back on yellow release the button and wait with the ignition on until the yellow tpc button goes out. Thats it.
If this hasnt worked you have a different spec and therefore a different way of doing it! Let me know and il guide you through it.
Hope this helps!
May 16, 2009 | 2005 BMW X5
Advantech TPC-1260T touchscreen pc blowing 5 amp supply fuse, after being powered down
I dont know how old the touch screen is. If its new send it back if not get a qualified electrician to take a look.
Mar 31, 2009 | Advantech TPC Series 5.7? Touch Panel...
TPC Mirage Patient Dental Chair TPC Logo
198 people viewed this question
Top TPC Medical Experts
Electro Med Services...
masud
masud
Rhonda Webster
Rhonda Webster
Are you a TPC Medical Expert? Answer questions, earn points and help others
