Question about Air Tools & Compressors
Quincy 240 compressor - Air Tools & Compressors
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 62 Answers
Quincy has a couple different models with 240 in the model number. I have linked to the user manuals of both. I hope you will find an answer in there!
http://www.bobsmanuals.com/Home_Improvement/Tools/Quincy/QRNG_240/manual
http://www.bobsmanuals.com/Home_Improvement/Tools/Quincy/QR_25_240/manual
Posted on Jun 17, 2015
How do you replace the check valve on a
using a small pipe wrench on ck valve body unscrew it by using ends of valve itself (lefty loosly) make sure to install new one with arrow pointing towards tank (important) and use a bit of teflon tape on threads to act as a seal take care not to crush body with wrench as this will affect valve working try and only use wrench on ends of valve
Apr 24, 2014 | Quincy Compressor Quincy 30 Rotary Screw...
Compressor shuts down and will not allow enough pressure run machine
Sounds like the oil is low or the cooler is dirty. If that's not the case then you have a defective thermal valve.
Dec 17, 2013 | Quincy Compressor Quincy QGS Rotary Screw...
How much oil for a quincy compressor model #216
What type of gauge belongs on the side of a 216 quincy compressor?
Also were can i locate one?
Thank you!
Tom
Mar 24, 2013 | Honda Quincy 17 - Gallon Air Compressor...
My oil temp has gone from the ave of 140 to 152 in about a week. everthing else is normal
check oil level in unit as over full will over heat oil. It is possible that there is a failing bearing or bush. Check outlet pipes for blockages from carbon build up from un burnt sump oil.
Jan 28, 2013 | Quincy Compressor Quincy 5 Air Compressor
Quincy model model QMB/T is leaking oil out of filter
tighten filter
check that the filter is not too tight and distorting the seal
replace the filter
Oct 24, 2012 | Quincy Compressor Quincy 30 Rotary Screw...
When the comp. shuts off the air bleeds back out the intake. what needs done to stop this It is a quincy model 350 2 stage compressor
You have one or more valves broken in the head and need to be replaced, and Quincy compressors require a special tool to remove and install valves.
Apr 29, 2010 | Air Tools & Compressors
Compressor has no oil pressure but seems to be running good
If you're sure its not just a bad oil pressure gauge, and there is no pressure, the oil pump is probably bad. If you don't run it hard, it may still last awhile, running more like a "splash lube" compressor. Still, if this is a pressure lubed Quincy, it's a good compressor - I'd fix the oil pump and it'll last for years.
Dec 15, 2009 | Honda Quincy 17 - Gallon Air Compressor...
Need to know torque specs for rod and head bolts on a quincy model 350-11 air compresser
25-35 ft. lbs. Never saw any air compressor head bolts any other torque range If that number is a little squishy for you, call Quincy up tomorrow at
212-222-7700
Aug 21, 2009 | Air Tools & Compressors
Kicking overloads but not consistantly
First: Most all compessors use check valves at the tank and an unloader to allow the compressor to start without a load. Make sure that system is unloading and that check valve is not leaking causing head pressure at start. Second: Too frequent starts and stops will cause motor to overheat. Check Quincy manual for max starts per hour. enjoy
Nov 14, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Air Tools & Compressors Logo
111 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
