Question about Goodman Heating & Cooling
Goodmans problems code 7076 keep appearing in the library
Goodman furnace furnace starts,flames start and shuts off after 10 sec. Replaced flame sensor still have same problem
if flame sensor is new, the board may not be properly recieving currrent from flame sensor to keep burners on
Feb 05, 2014 | Goodman Heating & Cooling
I need a manual for a Goodmans PE20S Microwave
Go to http://safemanuals.com/ It will come up as 'Diplodocs.com'. search under Goodmans and your model. To download, click on 'use code' and four little boxes will appear with numbers dropping into them. Put these 4 numbers into the opposite boxes and download your manual. It's FREE to use.
Feb 15, 2012 | Goodmans Televison & Video
After one heat cycle, the blower motor keeps running, even after cool down is complete. The furnace will not refire until i turn off the power and wait about 20 minutes for a reset.
your limit switch is opening up, that causes constant fan. Check for flashing codes after flame shuts off and fan continues. Check airflow, filters, lack on return air for possible hi temp limit problems.
Nov 17, 2011 | Goodman Heating & Cooling
I just registerd my unit and the deler name I put on it was wrong---I also brougjht the unit in June 2010--the dealer said go online, I am 82 yrs old, not able to get on computer until now when my daughter...
Under the circumstances you outlined, it may be better if you call. To speak with a Goodman Heating and Air Conditioning Consumer Affairs Representative from within the United States, call 1-877-254-4729.
Feb 28, 2011 | Goodman GPH1324H21A WallWindow Air...
CANT FIND THE CODE TO TUNE IN MY SKY REMOTE,MY TV IS A GOODMANS LD3266D
On your sky remote press interactive-skyactive-help-set up my remote follow instructions. If your Model No not on list keep checking for updated info. If no joy then contact goodmans customer services.
Sep 16, 2009 | Goodmans Televison & Video
Goodman Model GMNT100-4 Auto Power Down and Up until Temp.
Keep in mind all furnaces and circuit boards are not the same. Look on the back of the door to the blower compartment. You should find the list of diagnostic codes. Look up four blinks it should narrow down the problem. Although from the discription you gave it sounds lie the high limit control. When a high limit appears to be acting up it DOES NOT mean that the high limit needs replaced. The high limit just may be doing its job. This means that the furnace is overheating. Check your filters. Are all of your registers open? Is your blower set on the right speed? Is your blower going bad? Is the blower motor capacitor bad? Is your evaporator coil restricted? Just changing a high limit switch does not always solve the original problem!
Good luck....
Apr 01, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
11 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
