Question about Kitchen Ranges
Spark module for Kenmore 30 Gas Counter Unit model #91132059590
2 Suggested Answers
SOURCE: recived spark module for 6 burner gas stove on DCS gas oven/
I want to gas geyser using sparking unit (ckt Diagram)
Posted on Mar 28, 2009
Finding the right ignitor spark part for my gas range.
Go to the Sears parts sort online, if parts are available then you will find it there.
Jun 07, 2016 | Kenmore Kitchen Ranges
Kenmore gas range 790, not getting gas to the stove top, oven works, all 4 igniters fire when any knob is used. Is this a safety shutoff and how do I fix it?
Burner Spark Electrode Replacement - Kenmore Gas ...
? 2:23
www.youtube.com/watch?v=U0VcfMJPaiY
Nov 12, 2010 - Uploaded by RepairClinic.com
+Tony Eatinsky If the electrode is not damaged than the spark module ... I have a kenmore gas stove ( 362.7555190) that won't ignite unless I use a match. ... I have a Kenmore Elite 5 burnergas range top, it auto light continually sparks? .... You most likely will need to cut or grind off the screws and get new ...
kenmore model 790 gas range. the gas stove top burners ...
www.shopyourway.com > Manage My Life > Questions
kenmore model 790 gas range. the gas stove top burners stopped sparking. ... NOTE: I do not recommend measuring voltage unless you have experience and feel ... if the spark module is getting 120 volts when the burner knob is turned to the ...
Oct 19, 2015 | Kenmore Kitchen Ranges
I rebuilt my stihl ht75 pole saw with a new piston, rings, and housing, all OEM. It won't start now. I confirmed the orientation of the piston, it gets, gas (fresh) and has spark.
theres your problem. air gap on the module is 10 thou not 30 thou. set proper and if that is your only problem then unit will start
Sep 12, 2014 | Stihl Garden
I have a 30 in jgp336 gas cooktop that fails to ignite when it clicks what is wrong, it worked a few days ago and suddenly stopped working
usually the spark module is not put back together properly.
1 make sure the spark unit is clean
2 make sure the gas jet is pointing towards the sparker
3 make sure there is no aluminum foil or other metal near the sparker pulling the spark away from the gas
Jul 06, 2014 | GE 30 in. JGP336 Gas Cooktop
Burners on the gas range spark but gas does not come out of any of the burners. The electrical gas shut off valve does not open.
Try this website! http://www.managemylife.com/mmh/owner_manuals/8534/KENMORE-Free-Standing-Gas-L0212001 (Hope this helps. If you have anymore questions, let me know.)
Jan 28, 2013 | Heating & Cooling
Hi there. there is no spark to ignite the gas in oven.
You will need to replace the spark module if you don't hear any clicking, or there is no spark present when trying to ignite the gas.
To test the Spark Module:
When properly operating, the spark module repeatedly produces a spark at the ignitor accompanied by a sharp snapping sound.
  1. Turn off gas and power supply to unit.
  2. Check wiring diagram to verify all terminals and wire connections are correct and tight with no cuts in the wiring.
  3. Prepare to measure voltage on spark module from terminal L to N.
  4. Turn power supply back on.
  5. Turn top burner to LITE position.
  6. If no voltage is present on the meter, this will indicate the electrical circuit is interrupted before the spark module
  7. If voltage is present, then check ignitor.
  8. If ignitors are ok; then replace spark module.
To access the Spark Module:
  1. Turn off electrical power and gas to the range.
  2. Disconnect gas and power from unit.
  3. Remove screws securing top surface burners.
  4. Remove surface burner and disconnect spark ignitor wire from surface burner.
  5. Raise and remove maintop from unit.
  6. Remove screws securing spark module bracket.
  7. Disconnect wire terminals from spark module.
  8. Replace and reassemble in reverse order.
May 18, 2011 | Amana Ovens
I have a GE model jgp940 gas cooktop one of the four burner electrodes will not spark.
You have to determine if it is the electrode or the ignitor module and replace the component. A simple test is to swap the wires on the spark module for the non working one and see if the other electrode still works. If not the electrode is bad, if it does than the module is bad.
Eric
Dec 24, 2009 | GE 30 in. JGP336 Gas Cooktop
New cooktop-1 burner does not light automatic
find the spark module. Follow the spark wires to the module . unplug the one that doesn't work and plug in a working wire. If it sparks it the wire if it doesn't spark change module
May 16, 2009 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
Spark module will not stop after lighting burner
The module might not sense the flame: check electrical connections: wire (and its contacts0 and conections by fryer chasis; to be sure please bond with 18AWG wire pilot burner with spark module green wire.
MarKor
Mar 09, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
Kitchen Ranges Logo
81 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
