Question about Konica Minolta Minolta Bizhub C353 Copier
We can't copy bank checks with Foil Security seal
When we do the whole page comes out black - Service has been in and cannot make it work. We used to be able to do it but now we cannot.
  • Konica Minolta Master
  • 6,168 Answers
My microwave keypad doest not work apparently. It says "service may needed". How can solve this error.
HELLO.
The solution to your microwave problem is explained below.
Things You will Need
* Phillips screwdriver
* Foil
* Large ziplock baggie
* Tape
* 1 Unscrew the 2 screws in the top vent grill and remove it.
* 2 Unscrew the 1 screw above the computer keypad, then slide it up to unlock it and it will hinge down, revealing the computer circuit board behind the keypad.
* 3 Put a sheet of foil into the large ziplock bag and seal it up.
* 4 Then tape it to cover the whole circuit board in the back of the computer. You may have to let the wires stick out of the middle of your foil covering. The ziplock is to keep the metal foil from short circuiting anything on the computer, and the foil protects the circuit board from the small amount of leaking microwaves inside.
* 5 Lock the keypad back up and plugin the microwave to test it before screwing everything back together.
Thanks.
Sep 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Xerox DC12 printing black but copy works fine
Yor probles is caused for a pour conection from the fiery with the printer. Check disconecting and conecting again both conectors printer and scanner
Oct 26, 2009 | Xerox DocuColor 12 Printer
Black lines or smudge marks\running down the prints
Hello sir;The streak line from printing also should be from copy, because the line come from imaging unit, check the meter count if close to or over 50,000 then replace drum and drum blade, it will take care the problem.
The brother printer you need to replace imaging unit( drum unit).
Jun 01, 2009 | Brother Office Equipment & Supplies
HP J5780 All in one printer
Once try to make a scan and if we are getting line even while scanning. Then perform the steps given in the below webpage.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01129408&cc=us&lc=en&dlc=en&product=3301296
Directly go to step three and then try to make a copy.
If the issue still persists then power cycle the all-in-one.
  1. Turn the product off.
  2. Unplug the power cord from the product.
  3. Wait 30 seconds, and then reconnect the power cord to the product.
  4. Turn the product on.
  5. Make a color copy by pressing the Start Copy Color button on the control panel.
Now try to make a copy and check for the result. If the issue still persists then reset the all-in-one.
  1. Unplug the power cord from the product.
  2. Press and hold # and 6 while plugging in the power cord.
  3. Make a color copy of any document by pressing the Start Copy Color button on the control panel.
Jun 05, 2008 | HP Officejet J5780 All-In-One InkJet...
Printing color copies
check to see which cartridge you put in, photo magenta cartridges DO NOT work in the MP830. sounds silly but we see it all the time.
check to see if the short vertical black bar next to the magenta pattern looks ok, not brown or gray or streaky. if it is you may need a professional head flush, take the whole printer in for service.
Jun 01, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Image classD661 blank copy
If you just changed the toner cartridge, you probably forgot to remove the metal foil seal, from the side of the new toner cartridge.
Dec 07, 2007 | Canon imageCLASS D661 Digital Printer
Copying and scanning problem
The tech support at HP said its a hardware issue, especially if the following test results in a black page:
1) Open cover
2) Push scan button
if the bulb doesn't come on or the page is still black its a hardware issue.
Nov 10, 2007 | HP PSC 1610 All-In-One InkJet Printer
Konica Minolta Minolta Bizhub C353 Copier Logo
151 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
