Question about Danby DDR4588EE Dehumidifier
How do i get r410A owners manual - Danby DDR4588EE Dehumidifier
Owners manual for model fdl50s1 frigidaire dehumidifier
Good Afternoon Friend,
I understand you are looking for the owner's manual for your Frigidaire dehumidifier, model# FDL50S1. Attached is a link to your manual. Hope this is helpful.
-Best Regards-
WP
Frigidaire Manual Search Results
Jul 04, 2014 | Frigidaire Dehumidifiers
I have a danby premiere r410 a, the compressor will not come on
Hi There,
I would love to help you, however I am not sure which model you have. R410A is not a Danby model number. The correct number can be found on the back of the unit as well as on the front cover of the owners manual. The numbers usually begin with "DDR"
Jun 28, 2012 | Danby Dehumidifiers
I NEED AN MANUAL
You may download a copy of the manual from here.
Jun 27, 2012 | Dehumidifiers
DANBY PREMIERE DEHUMIDIFIER R410A OWNERS MANUAL
I have 70 pint premiere dehumidifier , and it's not producing any water . What should I do ?
Jan 27, 2012 | Dehumidifiers
What is the proper setting for Danby R410A?
R410A is refrigerant gas. I think you wanted to know, what humidity extraction level the controls should be set on. If it is really hot and humid in your area, set the humidity extraction level between 35 & 40%. If you have a mechanical control, turn the knob to Maximum.
Hope this helped you, Bradleyjo. Thanks for choosing FixYa.
Aug 06, 2011 | Danby DDR4588EE Dehumidifier
I have a DANBY PREMIERE R410A dehumidifier. I have misplaced the manual. I want to have the unit run for a fixed period of time (not all the time). HELP!!!
On the control panel the 3rd button from the left is the timer button. If you press this button when the unit is running the number display on the left will start blinking- use the up/down arrows to set the time that you want the unit to run.
If you press the timer button when the unit is off it will run on and off for the designated time you set- eg if you set 1 then every 1 hour the machine will switch on and run for 1 hour.
(The left # will just blink once you have the time you want just leave it and eventually the normal humidity setting reading will show)
Oct 18, 2010 | Danby Dehumidifiers
Danby DDR4588EE Dehumidifier Logo
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
