Question about SmartParts SP15MW (092566981886) Digital Picture Frame
Frame acts like it has no power but outlet is hot.
    President:
  • 1,383 Answers
Connect it to computer with usb cable and check it is detected or not.
Then scan memeory card with updated antivirus.
Posted on Jun 23, 2009
Why is the door frame so hot?
the door frame also acts as the condenser for the fridge hence the heat
Sep 11, 2014 | Refrigerators
My SPF3470/G7 frame does not turn on. It has been on constantly for 3 weeks and now it does not turn on at all.
First check to make sure the power plug is firmly seated in the frame. Verify the power cable is plugged into a working outlet. If the outlet is good, the cable fully inserted and the frame fails to turn on the power supply itself is faulty. New supplies can be found on ebay amongst other places.
Sep 21, 2011 | Philips (9FF2CME/37) Digital Picture Frame
On off not functioning Kodak appears for < 1 sec and then black. properly charged.
Try these troubleshooting steps:
1. Turn the frame off.
2. Unplug the power cable from the wall outlet.
3. Remove any memory card or flash disk from the frame.
4. Connect the power cable directly to a wall outlet.
5. Turn the frame on.
6. Use a paper clip to press the button inside the pinhole on the back of the frame.
If after trying the above steps and the frame still have the same problem, then we need
to send the frame in for a repair as per warranty guidelines.
Your frame will be repaired per warranty guidelines. A product is warranted for 1 year from the date-of-purchase. For an In-Warranty repair, a “Proof-of-Purchase” is required. If the repair center finds any customer induced damaged, the warranty will be voided and you will receive a notification from the repair center in such cases.
Process the repair at www.kodak.com/go/itg
Dec 25, 2009 | Kodak EasyShare EX1011 Digital Picture...
Is there anyway to make the power outlets HOT all
Well, yes, you could wire the outlets independently. Find hot power, fuse it, dicsonnect outlets from the wiring harness, and hook up your independent hot power source.
If you do not disconnect from the wiring harness, you can inadvertantly power other stuff.
Oct 04, 2009 | 2008 Toyota Highlander
Kodak EX1011 Screen blanks out
1 utf-8 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Try these troubleshooting steps:
Aug 19, 2009 | Kodak EasyShare EX1011 Digital Picture...
I have an old maytag electric dryer model #DE608 that has a three wire cord. I moved into a new home with a four hole dryer outlet. Can I switch the dryer electrical line from the existing three wire to a...
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
Jul 06, 2009 | Dryers
Frame will not power up or start.
The power adapters for the SP15MW's burn out very quickly so every thoug you have power in the outlet, it is not getting to the frame. Take the adapter to Radio Shack to have them test the voltage. If it's dead, you need to replace it and then the frame will work.
Jun 23, 2009 | SmartParts SP15MW (092566981886) Digital...
My digital picture frame was working and all of a sudden the screen went black and I can't get it to work - have tried everything
try these troubleshooting steps:
Apr 23, 2009 | Kodak EasyShare SV811 (8858946) Digital...
No power ay outlet
Maybe unpluged power/ground on plug. take off trim to access back of pwr outlet. It should have grnd wire and hot wire. Test hot wire with a different ground. If it tests ok, relocate ground/run a new one. If it has no power, recheck fuse or run a new hot wire from fuse panel.
Sep 09, 2008 | 1992 Jeep Cherokee Sport
Kenmoore refridgator side by side rubber gets hot
If you have a model with an energy saver switch turn the switch on. This reduces the heat to the mullion heater built into the door frame.
The door frame heater is used to prevent moisture from condensing on the seal surface around the door and acts as a thermal break between the outside and temperature inside the refrigerator.
May 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Open Questions:
See all SmartParts SP15MW (092566981886) Digital Picture Questions
SmartParts SP15MW (092566981886) Digital Picture Frame Logo
197 people viewed this question
Top SmartParts Photography Experts
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
