Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
What is 50:1 gas oil mix - Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
    Master:
  • Poulan Master
  • 645 Answers
That is the ratio of oil to gasoline needed to run this unit. Always use an"FD" rated oil. Better yet, use the pre-packaged fuels they have "FD" rated oils and 93 -95 non-ethanol fuel.
Posted on Dec 12, 2017
2 Suggested Answers
  • 731 Answers
SOURCE: how do u mix the
Mix 2 1/2 oz of 2 cycle oil into 1 gal of gas
Posted on Nov 25, 2010
Petrol & Oil mix - one third of oil to 1 gallon = what in litres
You need to go by the oil to gas ratio. 1/3rd what?
Google 50:1 (or whatever) mix in litres
and you will find this
Google 50 1 mix in litres Google Search
Mixing ratios. For a mixing ratio of 1 : 50 you need 5 litres of high-octane gas and 0.10 litres (100 ml) of STIHL two-stroke oil.
Dec 03, 2017 | Garden
Is there more oil 20 to 1 or 50 to 1 in to stroke mix
Hi Derek:
20 to 1 has 20 parts gas, 1 part oil
50 to 1 has 50 parts gas, 1 part oil
There is 2 1/2 times more oil in the 20 to 1 mix
Jun 24, 2015 | Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
How many ounces of oil do I add to gasoline to get a 50 to 1 mix?
Quite simple if the mix says 1:50 ( one to 50 ) ,it means for every one ounce of oil you add 50 ounces of gasoline.
If the instructions say 1/50 ( one of 50 parts) ,it means for every let us say 50 ounces of mix there are 49 ounces of gas and one ounce of oil.I use a one liter wine bottle !000 ml ,I put in 20 ml of oil fill bottle with gas and shake well-ps (mark bottle -hate to take a swig).If you are into avoirdupois system use 1 ounce oil add 50 ounces fresh gas .
Jul 26, 2014 | John Deere 2 Cycle Stroke Engine Motor Oil...
Does it take regular gas, or gas and oil mix? 50 to 1 ?
50:1 mix in the gas tank and bar oil in the oil tank. Fill your oil when you fill the gas. Keep the chain sharp.
Jan 08, 2011 | Ryobi Garden
What is the current oil/gas mix for the excalibur 22" hedge clippers? How about the new oils like Echo an Brigg/stration that are used at 50/1. Would 50/1 be acceptable in the weed eater excalibur?
50:1 is 50:1 no matter whose 2 cycle mix you use. 50:1 is 2.6 ounces of 2cycle mix to 1 gallon (US) of gasoline. I recommend strongly to use a brand that contains fuel stabilizer. It will come in a 3.2 ounce bottle...still 50:1. The premium 2 cycle oils will be semi-synthetic or full synthetic and will claim "no smoke"
Sep 27, 2010 | Weedeater Excalibur Gas Hedge 22" Trimmer...
I need to know the oil & gas mix ratio and what weight oil for the mix
On the container of 2 cycle oil you buy, it will have a mixing chart. 50:1 (means 50 parts of gas to 1 part of oil) usually uses around 4 ounces of 2 cycle oil to each gallon of gasoline. The other compartment is for bar & chain oil, that is what lubricates the bar & chain.
Sep 06, 2010 | Garden
First time to add gasoline, I am not sure how to mix oil and gas for ECHO PB-2100 ratio 50-1
50:1 means 50 parts gas to 1 part oil
you can mix a quart of gas with 1.5 oz of 2 sroke oil
May 06, 2010 | ECHO, Inc. PB-251C Handheld Blower
I have a techumseh snow blower 5.5 engine. I need to know what type of fuel it needs. It says on the outside something about a 50:1 oil gas mix and lists some types of oils. Where can I get these oils,...
go to your hardware store and ask for some 2 cycle 50:1 oil, mix that with a gallon of gas and you're good to go. Before you mix, make sure that you read the oil container for it's recommendations! You can purchase a small container of oil that is all measured for 1 gallon of gas
Feb 10, 2010 | Garden
I dont have the manual and Im not sure what ype of oil I should put on this chain saw. On the left The nob sais oil (which kind?) and on the right side it sais oil/gas mix (which kind?) what do i put on...
The Left knob needs chain oil. Available in most hardware stores. The right is gas mixed with 2 stroke motor oil. Usually a 50:1 mix. Ie. 50 parts gas to 1 part oil. 2 stroke oil comes with a built in measuring tool and directions printed on the bottle.
Jun 03, 2009 | Garden
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
59 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
