Bt com help btvision
I use a slingbox for viewing abroad, have changed from v box to youview box. slinbox working but still shows v box remote. how to change?
Dionnow
  • 61 Answers
SOURCE: slingbox configuration for remote viewing - How to set up ?
Access your router interface page by typing http://192.168.1.1 in the address bar of your browser, the login is Admin password is admin. Click on the "Administration" button on the top right. On the bottom you will see the option to enable UPnP. enable it there and you should be good to go.
Posted on Jan 09, 2008
Dionnow
  • 61 Answers
SOURCE: slingbox
SOURCE: Can't get Slingbox remote to work on DCH6416 DVR
Try using the QIP6416 (DVR) model to run it. very similar remote, most remote buttons the same only missing the page and day buttons. Otherwise not sure the problem.
Posted on Oct 04, 2009
SOURCE: I have a Bush 2878 TV and have just got BT vision
Thank you for the follow up. I have solved the problem by working my way through 4 figure numbers starting at 0001 and in fact the solution was 0009 - which was not a number that bt vision had suggested.
Nicky Spink
Posted on Oct 28, 2009
SOURCE: I WANT TO FIND OUT
0081 works fine for me. Took an hour but worth it. 22" Technika for BT Vision. Enjoy
Posted on Feb 12, 2011
How fast a internet speed do I need to use BT you view
See
Youview Public Knowledge Home
Recommend internet speed is minimum of 3mega bits per sec.
See the Connection Guide ' YouView Support video at 0.25 / 3:12
Sep 08, 2016 | BT Lands Phones
4 digit TV code to set up to BT youview
You might need to reset the remote control if the codes don't work.
If you've got the BT YouView remote that came with the box (with the 'BT Vision' button on it), hold down the two buttons either side of '0', whilst also holding down the power button for around 5 seconds. The blue light on the remote should flash three times to confirm it's successfully reset.
If you've got the retail YouView remote (with the 'TV' and 'PVR' buttons on it), press and hold the 'TV' button and the red coloured button at the same time for 5 seconds. The 'TV' and 'PVR' buttons should flash red 3 times to confirm.
Try your codes again after. I believe 4483 is the code in the setup guide.
May 28, 2015 | Televison & Video
What is the code for a Bush code to enter in the remote please? I used 0746 as shown under BT.com/ help/remote but it is not working for BT Youview box
0149,0114,0128. Check these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
May 07, 2015 | Televison & Video
Hoe do I connect a sonytv KDL26EX302 to bt tv
In order to connect your TV - any sort - you need:-
1. A BT broadband package.
2. A BT YouView box.
3. A network connection to your HomeHub or other router.
If one of these is missing (or if your broadband connection is too slow) you will not be able to connect to BT TV.
If you have all 3, then on the TV select the signal source to the socket that the YouView box is connected to and it will be installed automatically.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Televison & Video
How do I access bt sport using my remote ?
H
Please bear with me as I do a little explaining since I've just got it sorted myself ! BTSport is available to anyone with BT Broadband, however you cannot get it on a normal TV. I have a YouView box and with BT Infinity I can BTSport1, BTSport2 & ESPN on my YouView box (Channels 507, 608, 509) played through my TV. My TV however will not pick up the channels. Just says they are "scrambled".They also appear to be available on Sky (channels 413, 414, 417) and Virgin (channels 547, 548, 529).
I strongly suspect that the only way to see these channels without a YouView box, Sky, or Virgin is on line through your computer.
Hope this answers your enquiry.
Nov 12, 2014 | Computers & Internet
WHAT SKY BOX CAN I USE WITH A KV-28LS35U SONY IN SPAIN
Your TV has a SCART socket. So you can use anything from a plain "receive only" Sky box through to the recording HD boxes. As long as the box also has a SCART socket then the TV and box can be connected.
If you take a box abroad with you to leave there permanently then you'll need to think about what kind of contract (if any) you want. A Sky box without a viewing card will let you watch a broadly similar range of channels to Freeview in the UK. There's a useful comparison guide here: http://www.ukfree.tv/allchannels.php
Used Sky boxes are available cheap from Gum and the Facebook selling pages, or have a look in your local classifieds.
If you buy a recorder box, remember that the recording and Live Pause features are only available with a Sky subscription. They don't work with an expired viewing card or no viewing card at all. If you think you'd like to record programmes while abroad then consider a Freesat PVR instead. It will cost more in the short term, but you will have the same kind of functions as a Sky recorder box.
One other option is TV via the net. There's a device called Slingbox. It uses the internet to port your home's Sky box signal to you somewhere else in the world. You don't bother with a second Sky box, just add a Slingbox digitiser to the home Sky box and connect it to your internet service. In Spain, you have a Slingbox receiver connected to the internet and your TV. What you've then got is control of the UK Sky box, and those signals sent to you in Spain via a web connection. You operate the Sky box in the same way you would at home. The difference is that the TV is 1500 miles away.
Slingbox relies on you having a decent internet service in Spain. That might not be practical, or possible, or even desirable. But if you want to have your full Sky package in a second location without forking out for a whole year's subscription then it is one solution that wiorks.
Sep 16, 2014 | Televison & Video
What is the code for ctf4071
Digitrex TVs have just one generic code for the BT Youview box. The code is 478.
Sep 08, 2014 | Televison & Video
How can i have tv live streaming on my htc hd2
Try downloading the Playon app from the android marketplace and on your computer. Some tv stations have live broadcasts you are able to view through your 3g or wireless phone connection to your computer. www.playon.tv/playon has detailed instructions.
Mar 01, 2011 | HTC HD2 Smartphone
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
