Question about Car Audio & Video
I lost thr driver's instrument display on my holden captiva LX. All the fuses OK. What needs to check?
    President:
  • 1,114 Answers
The switch for your dash lights is probably bad. (The rotary dial to adjust dim to bright) can you still turn on the interior lights with the dial? it will "click" when in the fully bright mode and turn on the interior lights. If so, put a dark towel over the dash to mask the interior lights and look to see if the dash lights are on. If they are on, you've found the problem. (very common) Hope this helps
Posted on Jun 23, 2009
I have a 2009 holden captiva LX - the speedometer stopped at 40 even when engine switched off and radio switched off... havent had the car serviced in a while. Is it the fuse? cant locate fuse box
Hi this sounds as though one of the controllers have stuck in one of the modules this could be in the instrument cluster or in another module.
The only thing I can advise you to try is to disconnect the battery (earth terminal). leave it disconnected for at least 15 mins then reconnect and try. By doing this you will loose your radio, so make sure you have the code at hand to re enter. If you do not have the code it will mean a trip to a dealer.
There are only around 12 different codes and the dealer should have a list of them. If this doe's not work you will have to take it to a dealer. Good luck
May 01, 2018 | Holden Cars & Trucks
Hello I just bought a holden captiva 2007 lx. when I drive it all the lights comes on and when it changes gears it jumps
I think you should buy repair manual first for your vehicle after that it will be easy for you to solve the problem. Check the link may be you will find something useful here
holden
Dec 05, 2017 | Holden Cars & Trucks
Holden captiva rear door handle broken with child lock on..?
If door is in jammed state, open door by
repeatedly pressing the unlock button, while jiggle the inner or outer door handle this will help free up the
internal gears in the actuator that are jammed.
once the door is open.
Replace the door lock actuator with a revised
part;
Part No.: Description Qty:
96872800 LOCK,LHF DOOR (SX, CX, LX) 1
96872801 LOCK,RHF DOOR (SX, CX, LX) 1
96872811 LOCK,LHR DOOR (SX, CX, LX) 1
96872812 LOCK,RHR DOOR (SX, CX, LX) 1
96872803 LOCK,LHF DOOR (MAXX) 1
96872804 LOCK,RHF DOOR (MAXX) 1
96872813 LOCK,LHR DOOR (MAXX) 1
96872814 LOCK,RHR DOOR (MAXX) 1
Vehicle Torque Spec for door lock actuator
Captiva SX,CX, LX 10 Nm
Captiva MaXX 8 Nm
Apr 13, 2016 | Holden Cars & Trucks
Holden captiva display
Check the owners manual for fuse replacement.
If you need further help, reach me via phone at https://www.6ya.com/expert/frankie_091f536560a54e12
Apr 13, 2014 | Car Audio & Video
2007 holden captiva air bag light staying on
Hi Jeremy!
WOW! thank you very much about your tips!! I fix my airbag light just moving the yellow wire under my driver seat at NO COST!!
I got Captiva LX 2007 and the airbag lights on for month and I know Holden dealer charge a lot for any repairs!
Airbag light on - fixed now!! Thanks again!
Now i need to fix my Engine light - Holden dealer quote me for 4K-6K to replace the timing chain..
I got quote from the local mechanic for $2400 ---- a lot cheaper!!
Cheers
MItz
Dec 09, 2013 | 1999 Audi A6
How to remove stereo from 2008 holden captiva lx
firstly remove the negative terminal of the battery then just gently remove the air vents with screw driver by gently pulling the corners after that the four corner screw driver is used to remove all the screws then pull out the stereo and remove the coupler behind it
Sep 17, 2013 | Cars & Trucks
Captiva inner door handle won't open door
Holden Captiva 2006 cx model,doors won't open but the driver door does, how do I get the other three doors to open have put it in to electrician and they don't know what's wrong with it.
Nov 19, 2012 | Holden Cars & Trucks
Holden captiva lx brake lights not working
It is common for the plastic brake light switch to get jammed or brake. Remove and make sure small centre rod moves. To remove just turn and release light a light bulb. If switch fails it will prevent brake lights and can also prevent gear selector to move and also make brake pedal feel spungy.
Feb 28, 2012 | Cars & Trucks
Holden captiva is lacking in power, check engine light comes on and traction control lights come on and decline ascent light on dash shortly followed by service light and a large clunk sound. The motor...
I got a same problem in Holden Captiva diesel 2010 model as soon as you accelerate on traffic light the traction control light comes on engine light on dash, engine lack of power, turn the engne off for few seconds and goes ok but engine light stays on dash. Checked with the tech tool, it comes fuel metering code, can bus code... What it could be????. I've already changed fuel filter and did general service, still comes on. ANY IDEA PLEASE. OR I BURN THIS CRAPTIVA
Oct 13, 2011 | Cars & Trucks
Car Audio & Video Logo
495 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
