Question about Kyocera Torque Sprint
How do i get out of safe mod?
The phone was dropped in water puddle & immediately dried. service slowed. I restarted the phone & is now n safe mode.
My LG Transpyre that powers down immediately after i turn it on even though it has a full charge
check your power saving settings,start the device in safe mode, Safe Mode puts your phone in a diagnostic state (returned to default settings) so you can determine if a third-party app is causing your device to freeze/reset/run slow.check links below for more info.
press the helpful button and follow me on fixya for more tips and info
Power Saver On Off LG Transpyre
Restart the Device in Safe Mode LG Transpyre
Feb 03, 2016 | LG Computers & Internet
Tip
Login into safe mode.
You can use safe mode for a number of things...
Uninstalling programs that refuse to unistall in normal login;
Performing a system restore;
Scanning for dangerous viruses and Trojans;
and so many other things.
How ever, you can not install programs in safe mode because the installer is disabled.
In safe mod, you sound and graphics cards are also disabled, so you cant listen to anything or play video games.
To start your system in safe mode:
1. restart your system.
2. During system restart, press F8 before your Operating System (OS) is loaded, before the OS logo is displayed.
3. A list of options will be displayed, which include "Start Windows Normally","Safe Mode" among other options.
4. Select safe mod and press enter.
5. Give it a few seconds for safe mode to start, then log into your administrator account to start using safe mode.
on Jan 09, 2010 | Computers & Internet
Dropped phone in water dried it out now it works but it's in safe mode
Back it up while you can. It may not come out of safe mode.
Aug 07, 2013 | Cell Phones
By mistake i dropped my nokia c3 in water and the keypad doesnt work now
Usually when the mobile falls into the water you need to remove everything and immediately take it to a service center so that they will wipe it with some petrol. Now it doesnt work since you dropped it in water only. Check it again with a Nokia service provider.
May 26, 2012 | Nokia C3 Cell Phone
Dropped samsung intensity II in a puddle of water and it's stuck in boot block mode
Hi.
You should immediately take the battery out of the phone
Take the phone apart as much as you can.
The circuit board needs to be sprayed with acetone then blow-dried.
Take it to the nearest cell repair shop to do this. It should be cheap.
This will save your phone.
Hopefully its not too late.
Thanks for using fixya.
May 26, 2011 | Samsung Cell Phones
It always restarts in normal mode but does not restart in safe mod.whats the possible problems?
Sorry to read about your problem, I hope this helps you out.
you have to force the unit to start in safe mode.
To start up in safe mode:
Shut down your computer and wait 10 seconds.
Press the power button.
Immediately after you hear the startup tone, hold down the Shift key.
You should press the Shift key as soon as possible after you hear the startup tone, but not before.
Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | Computers & Internet
I dropped my Blackberry in a puddle of water and its not working. What can I do?
Remove the battery, turn the unit on it's back and allow any water to work its way out. Let the unit sit for a day or so. If you can't wait that long, take a blow dryer to it and blow out any water. When the unit appears to be completly dry, insert the battery and see if it boots up. If it doesn't, it may not be completely dry yet.
The 7290 is a pretty versatile unit. I dropped mine in a lake twice on the same camping trip. Both times I immediately removed the battery, laid it out on a rock and let the sun dry it. It booted up fine both times.
Cheers!
Dec 30, 2009 | RIM BlackBerry 7290
Acer5630 very slow
ok this is what you have to do,,,,rescan your computer for viruses.., download ccleaner, spyboot search and destroy, atf cleaner...restart your computer hit f8 to go to safe mod go to safe mode rerun all this programs in safe mod, clena everything what is bad ( it will be highlated) run disk defragment, restart your computer and let it boot normaly... it should run faster, if you can go to safe mod do all this in normal mode, after all of that got to run and type msconfig it will show you on startup tab what programs are loaded on startupo of win xo uncehc those that you don't want or those that are suspicious to you.... and post me back if you ancourted any problems ....
Nov 08, 2009 | Acer Aspire 5630 Notebook
Dropped phone in puddle only screen is broken PLEASE HELP MEE!!!!
Unfortunately, I would suggest you not trying to fix this. The reason is once water gets inside, any of the parts that got wet will eventually corrode. It might work a day, a week, I actually had my phone work 2 months, then it will stop. You could replace the screen and have it work right away, but nobody could gaurantee that it will continue.
Jan 28, 2009 | Motorola Mobility RAZR V3
Dropped phone in water puddle
there is nothing you can do but to bring it to a service center.. water and electronics don't mix,, maybe the battery is working fine but i doubt if the phone will.. if i were you id bring it to a able technician to check your mobile..
Mar 29, 2008 | Samsung SGH-A707 Cellular Phone
Kyocera Torque Sprint Logo
Top Kyocera Cell Phones Experts
Sue Hale
Level 1 Expert
Shane Martin
Level 1 Expert
Are you a Kyocera Cell Phone Expert? Answer questions, earn points and help others
