Question about Husqvarna Zero Turn Mower Z5426
Spring for engaging blades on husqvarna RZ came off
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 376 Answers
SOURCE: knob on lawn tractor for blade engagement
Sounds like you need a new PTO switch.
Posted on Jun 15, 2009
SOURCE: Blades will not engage on Husqvarna riding mower.
I have a Husqvarna GTH2548 and the blades will not engage. It is free from all debrie
Posted on Sep 04, 2010
philwalker78
  • 608 Answers
SOURCE: Husqvarna YTH 2448 shuts off when I let out clutch or engagae mower blades
Hi, check or replace the switch on the seat, basically its not telling the safety system that you are on the seat. Regards Phil.
Posted on Jul 08, 2012
H2_Brad
  • 425 Answers
SOURCE: husqvarna yth20k46 tractor sputters when blade is first engaged, then evens out?
When you put a load on the engine the governor opens the throttle plate on the carb further to allow more fuel. Sometimes it can take a second for the engine to catch up when this happens. As long as the tractor runs fine once it catches back up I wouldn't worry about it.
Posted on Aug 24, 2012
Husqvarna Riding Mower when turn lever blade will not engage.
If the engagement is done by lever, yes it is controlled by cable. It could be disconnected or the cable could be broken.
Oct 29, 2016 | Husqvarna Garden
Blades won't engage on my zero turn 50" cut husqvarna (approx2011) I found a 7" spring on the ground and don't know where it goes back on. Can u help
Looking underneath the mower on top of the deck there should be a flat metal arm with a flat faced pulley on the end. This pulley pushes against the belt that drives the mower deck . The spring should be hooked on that arm and pulled tight over to a place on the deck and this is what keeps the belt tight enough to turn the blades when you engage the pto switch. My recommendations to put this back on is to remove the belt pulley cover on the deck right side roll the belt off at that pulley giving you a bunch of slack so you can hook up the spring and put the belt in the right position on everything else then go back to the deck right hand pulley start putting the belt back on that pulley and when it is to tight to get it all the way on reach under the deck and use the blade as leverage to finish turning the pulley and walk that belt on the rest of the way ,it will not hurt a thing, all you are doing is pulling that 7 inch spring over like it was intended to be, then replace the cover on the deck spindle.
May 17, 2016 | Husqvarna Garden
Governor,carb problem
Sounds like the linkage spring is not working correctly or was never replaced during rebuild. I would replace that spring as a starting point.
Aug 01, 2015 | Husqvarna Garden
when you actuate the "engage blade" lever, two things may occur,
First, a mechanical action, a spring moves to put tension onto the belt.
Second; at the end of its run, actuate a switch (PTF switch) to engage the clutch that moves the pulleys that consequentially move the blades.
if the tensioner is not moving , check if spring has come lose, undone or broken, (more likely in your case) or check the PTF switch.
any other assistance, contact me, good luck.
Apr 20, 2014 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Clutch spring
I am guessing that this is a problem that has just appeared. In which case it sounds like the spring may be worn out. The linkage itself may be worn out also. Check to be sure that nothing is loose, nuts, bolts, you get the idea.
Mar 25, 2014 | Husqvarna Garden
When I engage the blades nothing happens. Any ideas?
I have a YTH 150 with a similar problem. The mower has an electrically powered clutch which is activated when you engage the blade button. If the drive belt has no tension on it, engaging the clutch doesn't do anything because the drive wheel will just spin but the blades won't. Look for broken tension springs on the mower deck and replace.
Jul 05, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Replacing bar on husqvarna 340 saw. Appears to be a spring attached to guard that will not allow the guard to slide off. Does spring have a certain amount of tension and how is it removed so guard will...
Sounds like the blade brake is engaged. You should be able to pull the blade brake handle, located on top of the saw, in front of the top handle, back towards the handle to disengage it. You can find replacement bars, chains & sprockets for your saw at Partsbuggy.com.
Sep 24, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Could be a broken belt, loose belt (stretched) or something is under the mower deck jamming the blades. (stick for an example)
Apr 14, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Zero Turn Mower Z5426 Logo
24 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
