Question about Adapters.com Bluetooth USB Adapater, USB to Bluetooth Dongle, Class 2, Connects Your PC to Wireless Bluetooth Dev... (192057001)
How can i connect the nokia 8800e 1 with my notebook via bluetooth
I want to connect the phone with my notebook, then i was asked to log in a connection code, but i ain't got that code, can you help me?
How do I connect my Nokia 225 mobile phone to Hands free Nissan Note via Bluetooth
Hi, I had trouble connecting to a corsa with my Nokia, I Had to try serveral things to get it working. first of all is you phone bluetooth name visible?, is your bluetooth name different from other bluetooth device names stored on the car?
Have you tried a bluetooth search from the car to the phone and from the phone to the car?, did either or both devices ask for a pin number(usually 0000)? If you can offer anymore more infomation that would be great.
Mar 09, 2015 | Nokia Cell Phones
Nokia 8800e-1 asking the restriction code imei:352688/90/080018/8
Hi you can try Mobileunlocksolutions.com to get restriction code for your Nokia 8800 and get it unlocked..
Feb 14, 2012 | Cell Phones
How to transfer music to N70 without using a card reader or bluetooth ? my card reader is missing ..
Good Day,
Transferring file to a PC from an N70 phone, can be done in three ways
1: via Bluetooth 2: via memory card (by the use of memory card reader) 3: via Nokia PC Suite using standard N70 (DKU-2) Cable chiefmecha_4.jpg
I guess you are left the last option, which is I am sure you have a cable for your phone. Because it is included in the box when you bought the phone.
But before you can actually connect your phone to your PC, even if you have the cable, you must install Nokia PC Suite first. Just go here and download the software. http://nds1.nokia.com/files/support/global/phones/software/Nokia_PC_Suite_eng_web.exe
After installing you can go and connect the cable to your N70 phone and connect to a USB port on your PC. The phone may ask you on its screen to choose what kind of connectivity you want, if you want to just transfer files, you may just choose Disk option or removable disk access, and access its MMC via the windows explorer just like a card reader.
Hope this helps you. Thank you for using Fixya.
Aug 09, 2011 | Nokia N70 Cellular Phone
I cannot pair a Nokia 6700 with Samsung Galaxy s11 via Bluetooth. The Galaxy recognises the Nokia, but says problem with PIN nunber or Password. I don't know of any such PIN or Password. Cannot connect...
If you need the pairing code for Bluetooth to connect just pairing with the same code in each device
for example if your device asking for code just enter 1 in your device ( Samsung galaxy) and enter the same code (it means 1 for Nokia), the code will depend on you but the important the code must be same each other.
Jun 05, 2011 | Samsung Cell Phones
I WANT TO CONNECT N 72 TO MY PC
N72 can be connected to your PC in two ways.
1. By USB cable
2.Via Bluetooth.
Bluetooth means you need to buy a device called Bluetooth dongle to provide bluetooth connectivity to your system.
For both usb and bluetooth, you need a software called Nokia PC Suite to access the mobile contents and for data transfer
Aug 03, 2010 | Nokia N72 Cellular Phone
How i connect my note book to my htc bia bluetooth
Hi,this is a detailed step on how to connect your htc to your notebook via bluetooth. STEP 1. Turn on the bluetooth of your htc which is accesed at the connnectivity settings of your phone.
STEP 2 Ensure you also put on the bluetooth on your notebook,most notebooks have a single button in front of the keyboard,to turn on the bluetooth. STEP 3 You now go to the bluetooth settings on your phone,and click on 'add device'.when you click on it,it requests for a pass code,when this is done for the first time,this pass code can be any 4 digits of your choice. STEP4 After entering the pass code on the phone,a pop up shows on your notebook requesting for the same pass code you entered on your phone. Ensure you enter the same pass code for both the phone and notebook,if not the devices won't pair via bluetooth.
STEP 5. After entering the pass code on the notebook,the notebook is automatically paired with the phone via bluetooth,afterwards you can be able to transfer files between the phone and the notebook via bluetooth.
Thanks and take care
Apr 21, 2010 | HTC P3450 Touch Black Unlocked...
Whenever I log onto windows vista on my hp 6730s laptop with the bluetooth button on and my nokia e51 also with its bluetooth on I get the message three times that drivers for bluetooth peripheral device...
It is because the software for your Nokia phone is not yet installed on your computer for the bluetooth connection... This happened to me as well... so you are not connecting via bluetooth just go to your Control Panel and go to Systems then Hardware and then Device Manager under Other devices, uninstall everything and go to your bluetooth devices and remove the Nokia phone that is in the box (Control Panel >> Bluetooth Devices) you should not be asked again for the drivers once you have rebooted after this...
Mar 21, 2010 | IOGear (GBU221) Bluetooth Wireless Adapter
Transfer data from Nokia N958GB to i phone 3G
go at your blootooth profile and paired this ph and get connected
Apr 04, 2009 | Nokia N95 Cellular Phone
I can't receive anything via bluetooth
When transfering dta from another phone by bluetooth it asks for the password usually 1-4 numbers to confirm authencity just enter 0 in your phone and 0 in the other phone when password is aksed for an easy solution . When you receive Mp3 or Video via bluetooth it's received a message and stored in your phone's main memory . Go to Messaging and setting and change default storage location to Memeory Card , don;t forget to copy all your messages when asked . Now you can utlizie the memory card for media received by bluetooth
Jan 04, 2009 | Nokia N72 Cellular Phone
Adapters.com Bluetooth USB Adapater, USB to Bluetooth Dongle, Class 2, Connects Your PC to Wireless Bluetooth Dev... (192057001) Logo
Top Adapters.com Computers & Internet Experts
JP Services
JP Services
Jeff richtman
Jeff richtman
Are you an Adapters.com Computer and Internet Expert? Answer questions, earn points and help others
