Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Konica Minolta Bizhub c550, reads 2 codes 225B & 6751 I know it needs a power supply, but it makes a grinding sound, jams constantly, leaves imprint marks on paper, colors bleed & will not pri
Why does the ink bleed on the papers being copied? Why does imprints show up on the papers, like impressions on paper? What does the 6751 trouble code indicate? Why does the papers constantly jams when copier is not being used for a while? I understand the 225B code indicates the copier needs a power supply; how many & problems will the power supply resolve?
  • Konica Minolta Master
  • 6,161 Answers
Why do you need a Power supply? Neither codes deal with that. The 6751 is dealing with your scanner CCD which is located under the big glass on the right side that large black item. It could be bad or needs a alignment, the second deals with the Black image unit and or toner for black using 3rd party????? or OEM toners. Replace both he black image unit and black toner using OEM not 3rd party. As for jamming where does it jam? When was the last time the draw rollers where clean and or replaced? When was the last time the machine was cleaned, Gradation? and Registration? test done. Image units toned up? High end copier likes this needs to be keep up!!!!!
As for the imprints replace the FUSER UNIT (HOT PART) What color Ink bleeds replace that color image unit.
Posted on Dec 29, 2015
  • 19 Answers
SOURCE: bizhub 350 error code
c3852 means low fuser(hot section) temp setting. hold down utility or stop key, then you should be abel to do trouble reset. if problem persist it would most likely be a lamp or a sensor, which will require a technician to come out.
Posted on Apr 16, 2008
  • 18 Answers
SOURCE: Konica Minolta 2500W shows error.
Okay, the driver for the printer (hal.dll) needs to be reinstalled.
Do the following:
Press the windows key and R
Type in command
In the command prompt that comes up:
Type in cd C:\Windows\System32
Type in taskkill /f /im "hal.dll"
Type in del hal.dll
Then restart your computer
What taskkill does is kill the printer application that is using the driver so you can delete it. After your system restarts, Windows will automatically reinstall the printer driver, and the problem will be fixed!
Posted on Mar 13, 2009
  • 1294 Answers
SOURCE: konica Minolta bizhub 250 jammed but no paper
Please check the sensors and actuators ,open & close front door to reset nisfeed.Clarification Top feed = Automatic Document Feeder?If YES,please verify misfeed paper beetween coverplaten and feedbelt(Yellow).Is necessary disassembly the ADF.Good luck.You will find a little paper.
Posted on Jul 31, 2009
  • 51 Answers
SOURCE: hello, we have konica minolta bizhub c550, i
30deccd.jpg TRY
Posted on Sep 17, 2009
  • 44 Answers
SOURCE: on the bizhub C550 an error code C0204..... won't
Two things 1) check to see if there is paper in the back of the of the tray where it meets the back wall (that would prevent the paper tray from rising. 2) there is an upper limit sensor on the paper feed (thats where the rollers are) so check to see if any bits of paper blocking the sensors. If you find it, reset the machine and it will see the tray.
Posted on Dec 14, 2009
Konica minolta c550 displaying a code C-B116, how can I solve this please?
Konica Minolta Ineo 223 Fax card Error C-B003 \ C-B116 ...
www.copytechnet.com > ... > Copier Technical Discussion > Konica Minolta
Feb 6, 2014 - 10 posts - ‎6 authors
The other errors that appear are C-B116 & C-B003, i've tried the below : 1. .... Also ensure you have the fax set to the correct country code. Error Code konicaminolta bizhub500 error code C-B003
7 Sep 2010
How Do I Access Techrep / Service Mode? - Page 4
18 Jul 2008
More results from www.copytechnet.com
Error code C-B116, what does it mean? - Fixya
www.fixya.com/support/t1535504-error_code_c_b116_mean Jan 13, 2009 - Touch the following code on the trouble code display screen. Stop ? 0 ? 7 ... 4 Answers. SOURCE: Konica Minolta Bizhub C352 error C-B116.
Bizhub c250 code c-b116 - Fixya
www.fixya.com/support/t11325427-bizhub_c250_code_c_b116 Jan 17, 2012 - bizhub c250 code c-b116 code c-b116 on the bizhub c250. ... on the display you'll see the Trouble reset button on the display, touch it and turn ...
Konica Minolta Bizhub C352 error C-B116 - Printer
www.allprintersmn.com/konica-minolta-bizhub.../q724088-konica_minolta_bizhub_c... fix Printers & Copiers - Konica Minolta Bizhub C352 error C-B116 about Printers & Copiers. ... Konica Minolta BizHub C550 Error Message ... ERROR CODE C11B2 ON DISPLAY - Konica Minolta bizhub C250 All-In-One Laser Printer. konica minolta c550 displaying code B116 Google Search
Mar 15, 2017 | Konica Minolta Office Equipment & Supplies
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
www.fixyourownprinter.com/posts/40820
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ...
www.fixya.com > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
C550 cooling fan not functioning, what can i do to make work?
Konica Minolta bizhub cooling fan not working Questions ...
www.fixya.com/tags/cooling_fan_not_working/printers/konica.../bizhub
Konica Minolta bizhub printers & copiers cooling fan not working related questions and answers. Ask your Konica ... Question about Bizhub C550. 1 Answer ...
Konica Minolta Bizhub C550 Cooling fan power - Questions ...
www.fixya.com > ... > bizhub > Konica Minolta Bizhub C550
konica minolta bizhub c252 error c-5351 C - 5351 Is power cooling fan problem.Verify the cooling fan connectors and clean.For reset open/close the front door.
cooling fan not operating properly - HP Support Forum
Nov 29, 2015 | Cars & Trucks
Konica minolta bizup c550 printing black copy what will i do?
The corona housing for the back drum need to be replaced. Get a new black image unit drum and developer units
Aug 15, 2014 | Konica Minolta Bizhub C 353, Bizhub...
Why do I have a Trouble code c9401 on biz hub c550 Konica Minolta?
After doing this the code comes back replace the Exposure lamp assy. big bright light under the glass.
1.
Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after
and check if the machine starts correctly.
May 20, 2014 | Konica Minolta Bizhub C550
Error code c-6751 on konica minolta c450
The CCD is bad raise the document feeder. under the big glass to your left is the CCD assy. Unless you know which screws to remove you remove the wrong ones and all your images will forever be messed up. so recommend a tech come out and replaced it. have open close the front door to reset the code
Apr 05, 2014 | Konica Minolta bizhub C450 Scanner
Paper jam laser
Could be dirt or a bit of paper stuck to one of the rollers or one of the rollers has jammed. You may have to strip it down a bit to get access to clear foreign objects.
Nov 25, 2013 | Konica Minolta Bizhub C550
Error code c-6751 on konica minolta c451
C-6751 CCD clamp gain adjustement error.To reset turn OFF the copier.Press and keep pressed the Utility key and turn ON the copioer and wait for the Trouble reset message appaire on the display.Realease the Utility key and touch the trouble reset then turn OFF the copier.Wait 1 minutes and turn ON.
Mar 14, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
80 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
