Question about Toshiba E-Studio 456 Copier
Why when using Windows 8 does no pop-up code box appear
How do i reset my gateway mt6705 computor back to factory setting
Step 1:
Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management." Click "Restore" when the Gateway Recovery Management window pops up, which will take the system back to the default factory specifications. A box will pop up asking for confirmation, click "Yes" and then "Start." You may have to enter a password as well, but only if your particular Gateway had a password set. Wait for the computer to restart. A "Restore from factory default" box will appear, requiring you to click "Next" twice in a row. Click "OK" in the box that appears next, and wait for the hard drive partition to be created. The factory default installation will then be moved over to the hard drive. Click "OK" in the box that appears and wait for a second Gateway restart. Several minutes will pass as Windows "starts for the first time." When restarting finally finishes, a "Set Up Windows" dialog box will appear. Click "Next," followed by checking the license agreement box, and then "Next" again. Enter a user name and picture, if desired, and a computer name. Also, customize the background wallpaper for your desktop, optionally. Click "Next." Click "Use Recommended Settings" on the Protect Windows-based dialog box that pops up. Set your correct date and time settings in the next box. Select your location in the following screen. Click "Next," followed by "Start" to finish. Wait while Windows checks for your individual Gateway computer specifications and adjusts accordingly. This will likely take several minutes, so leaving your computer for a short time is fine. Windows will then prepare your hardware and finish your Gateway restoration process, including the installation of Gateway Recovery Management. Once completed, your Gateway is good to go and ready at factory settings.
Feb 25, 2013 | Gateway Computers & Internet
Tip
Stop Code 28 from appearing on Windows XP
Microsoft Help and Support says that "Code 28 (The drivers for this device are not installed)" appears when the Windows Sound System Compatible Driver for the Windows 2000 operating system is deleted upon the upgrade to Windows XP. It's possible to repair this code.
Instructions
1 Click on "Start."
2 On the "Start" menu, click on "Control Panel."
3 In the "Control Panel" folder, click on "Performance and Maintenance."
4 Click on the "System" folder in the "Performance and Maintenance" folder.
5 Click on the tab titled "Hardware."
6 Click on the box that says "Device Manager."
7 Click on "Sound, Video, and Game Controllers."
8 Right-click on the device that prompts Windows XP to display Code 28 (it should be Windows Sound System Compatible Driver, also called the WDM driver). A drop-down menu will appear.
9 Click on "Update" and an Update Wizard will guide you through the installation of a new device driver, which should stop Code 28 from appearing on Windows XP.
on Nov 03, 2010 | Computers & Internet
I factory reset my gateway zx series all-IN-ONE because the recovery disks i created wouldnt work.then i reinstalled windows and now i have nothing in my programs list n i cant log in cuz they want a...
Hope this helps.
Jan 21, 2013 | Computers & Internet
Do you need a disc to restore a 450rog
hope this helps
Sep 21, 2012 | Gateway 450ROG Notebook
How do I reset it to factory?
hope this helps
Sep 08, 2012 | Gateway 832GM PC Desktop
Restore gateway sx2850
· Click "Start" on your Windows desktop. Navigate through "All Programs" and "Gateway." Click on "Gateway Recovery Management."
· 2
· 3
· 4
· 5
· 6
· 7
· 8
hope this helps
Jul 19, 2012 | Acer Computers & Internet
I want to know how to restore my DX4200-09 to factory settings?
· 2
· 3
· 4
· 5
· 6
· 7
· 8
hope this helps
Jun 25, 2012 | Gateway DX4200-09 PC Desktop
Toshiba satellite L300 will not boot up. error code 0xc00000e9
What you can do is attempt to repair the system using System Restore or startup repair. I would suggest trying startup repair first.
Method 1: Use the Windows Recovery Environment (WinRE) to run System Restore
1. Insert the Windows Vista or Windows 7 installation disc into the disc drive, and then start the computer.
2. Press a key when the message indicating "Press any key to boot from CD or DVD ...". appears.
3. Select a language, a time and currency, and a keyboard or input method, and then click Next.
4. Click Repair your computer.
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next
6. At the System Recovery Options Dialog Box, click on System Restore.
7. Follow the System Restore Wizard instruction as usual and choose the appropriate restore point.
8. Click Finish to restore the system.
Method 2: Startup Repair from the Windows Recovery Environment (WinRE)
5. In the System Recovery Options dialog box, choose the drive of your Windows installation and click Next.
6. At the System Recovery Options Dialog Box, click on Repair your computer.
7. (Click the operating system that you want to repair), and then click Next.
8. In the System Recovery Options dialog box, click Startup Repair.
Hope this helps
Ray
Mar 07, 2011 | Computers & Internet
Explorer 8 removal
Steps for Windows 7 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  1. Close all programs.
  2. Click Start Collapse this image Expand this imagevistastartbutton.jpg, and then click Control Panel.
  3. Under Programs, click Uninstall a program.
  4. In the tasks pane, click Turn Windows features on or off.
  5. In the list of windows features, clear the check box next to Internet Explorer 8.
  6. You receive a warning message in a pop-up window. Click Yes.
Internet Explorer 8 will now be uninstalled. The system will restart after the installation.
Steps for Windows XP or for Windows Server 2003 loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start, and then click Control Panel.
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    Note If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows XP or for Windows Server 2003.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
Please rate the answer. Thank you!
Apr 27, 2010 | Microsoft Internet Explorer 8
Can't get rid of bloodhound pdf 8 and now I can't get into my user profile
You are going to have to get your hard drive wiped and windows re-installed then you will be able to have your computer up and running again!
May 07, 2009 | Computers & Internet
Toshiba E-Studio 456 Copier Logo
13 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
