Question about Scotsman Kitchen Appliances - Others
Why does the the light blink on the red ice cube logo on the scotsman ice machine?
    Novelist:
    Champion:
  • Scotsman Expert
  • 373 Answers
That means it is not freezing pull front cover and then you can reed the error code and if you will give me the code i can help you with it.
Posted on Jul 15, 2014
  • Hymine Oosthuysen
    Hymine Oosthuysen Dec 16, 2017
    Clean air filter and or water circuit
  • Hymine Oosthuysen
    The error is : clean air filter (what I did) or water circuit
Therinnaiguy
  • 1420 Answers
SOURCE: cme256 scotsman ice machine
Clean the bin eyes found in the back of the ice machine where the shoot narrows. Look on the left and right sides of the unit, you will see plastic vanes that are pushed into rubber grommets. Just pull the eyes out and clean with ice machine cleaner.
Posted on Apr 21, 2010
  • 129 Answers
SOURCE: Scotsman ice machine is not making ice. There is
The manual has an exploded parts diagram use as guide to locate parts.
First check the timer, you can manually turn it through a cycle or watch it rotate on its own.
Check the water inlet solenoid valve. if all looks well and you have definite water flow past the valve, then
Check spray pump. You have to remove the rear panel. The pump has a fan on the top. spin the fan if it is at all tight the ;pump is bad.
I have owned 2 of these units and have had failures of all of the above parts over the years.
Posted on Feb 25, 2010
TheMobilian
  • 8220 Answers
SOURCE: I have a new DCE33 scotsman ice machine. No spray small flow
Could be in need of cleaning with some nickleguard ice machine cleaner. Or maybe a restriction in the pump? How about a scotsman repair manual?
I have both. Hope this one is it
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Nov 05, 2009
TheMobilian
  • 8220 Answers
SOURCE: Scotsman ice machine problems.
Well it is making ice cubes alright just too thick right? I would give it a good cleaning with nickleguard and retry. If it is still doing the same thing I would replace the ice thickness switch.
Posted on Mar 01, 2009
  • 7 Answers
SOURCE: scotsman icemachine m# DCE33A-1WB ice cubes are hollow
Have several of these machines here. The cube size control and the hot gas valve are common problems. I've had several that had one or the other. Generally if the cubes are forming and not harvesting the cube size control is likely the culprit. If no ice is forming then the hot gas valve may be leaking by or several of my machines have had leaks around this valve. The replacement part is not the same as the OEM part.
The charge is tricky and no access valves on this machine. Weighing in the charge is preferred.
Posted on Aug 23, 2010
Status light solid red, with blinking.diagnostic blank wont reset
Push and hold the off button for 4 secs then freeze button but chances are itll happen again until problem is corrected
Jul 15, 2015 | Scotsman CU1526SA-1A 150 Lb Self-Contained...
Why Scotsman CM3 ice machine shows diagnostics water problem?
should you have any questions, Thanks John Tripp Appliance 911
First let's look through the different service manuals. CM3 Water level sense diagnosticsDOWNLOAD
Head Pressure Control Kit - CM3DOWNLOAD
Reduce Air in CM3 ModelsDOWNLOAD
Replacement of the CM3 controllerDOWNLOAD
Service Handbook to 2007 - CM/CM3DOWNLOAD . I am here should you have any questions, Thanks John Tripp Appliance 911
May 15, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Stops cycling intermittantly
Any advisory lights on, e.g. bin full? Clean all sensors and make sure dump valve isn't letting water gradually drain out
Apr 04, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Scotsman 306 flashing two red blinks
From which light the water or refrigeration? E TOf
Mar 18, 2014 | Scotsman Ice Maker 600LB CM3 30inW...
Mv 450 scotsman ice machine
Remove the front panel to the ice maker. There should be a control panel that will give you some more info on the fault. I am guessing that you are dealing with a short freeze cycle, thin ice, or harvest error.
May 13, 2013 | Scotsman Cooled Modular Contour Cuber Air...
My scotsman ice machine have a switch board that keep showing me red light on refrigeration and won't make any Ice.
Scotsman provides a lot of service manuals for their ice machines. It will really help if you could provide a model number so I can possibly find the correct manual and information that just may help you, Thanks Sea Breeze
Apr 04, 2013 | Kitchen Appliances - Others
How do I fix the max harvest time shutdown
The ice sensors are not sensing the ice fall.Wave your hand in front of them the bin full light should blink.If it doesnt clean eyes and conectors.If it still doesnt blink change them they are bad.
May 21, 2011 | Scotsman Ice Maker 600LB CM3 30inW...
Kitchen Appliances - Others Logo
253 people viewed this question
Top Scotsman Kitchen Appliances - Others Experts
John Tripp
John Tripp
Tim Whalen
Beto Flores
Beto Flores
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
