Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
52209100 Sears side by side will not stop making ice. What do I do?
I went on another website and found the answer. Looks like I need to replace the optical sensor. I found it at partstap.com for about $15 less than anywhere else.
Posted on Jun 24, 2009
Why is my icemaker not working on Sears Kenmore 50562991
Two of my refrigerators stopped making ice because of frozen water lines going to the ice maker inside of the freezer door. I thawed the lines by unplugging the refrigerator and used a hair drier around the ice maker till all the frost was gone. After I plugged it in I heard water going to the ice maker. If you remove the ice bin you can check the ice tray to see if it has ice in it. If it is empty it is not getting water. It could also be a bad Solenoid Water Valve.
Jul 08, 2014 | Kenmore Side by Side Refrigerator
Ice maker stopped working...water works, ice tray has water, ice maker is turned on. curious if I should just replace the motor or if it could be something else
If your ice maker is not making ice and you poured water into the ice maker, that would indicate the ice maker is not cycling. If you have any make or model except a whirlpool, kitchenaid or sears kenmore, if you replace the ice maker, you will be making ice in no time. If you have one of the aforementioned brands, AND the ice BUCKET is mounted on the door, you will have to replace the electric eye boards on either side wall as well, as these often short, damaging the icemaker electronics in the process.
Nov 09, 2010 | Kenmore Refrigerators
Ice Maker on Whirlpool Side by Sidek stopped making ice
Go to sears.com, select "Parts Direct", enter model number and wait for unit to be displayed, find ice maker part number and price.
Oct 01, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
Side by side won't dispense ice.
Take the ice container that has the auger inside it and press the door switch in while you press the dispenser. If the auger motor in the back works empty the ice container and see if there may be frozen ice preventing it from turning. If yes then defrost and dry the container and replace. If this does not solve the problem get me your model number for example 213.256489 for Sears and I will help you track the problem down. Sea Breeze
Jul 23, 2009 | Refrigerators
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker not making ice
The most likely cause is the water solenoid behind the fridge. Take an ohm meter and test across the two terminals and it should NOT ohm out (beep). If it does not ohm out I would replace the P.C. Board kit, emitter & receiver icemaker control.
Jan 04, 2009 | Kenmore 53642 / 53644 Side by Side...
Ice maker does not work
is there any noise to it or did it just burn out
theres a couple things it could be iced up and all it requires is a thaw
also air in the line could make the icer not work properly
also you can do it your self i worked on them its one wire block 4 to 6 screws pull out have new ice maker ready put it back in ice makers are simple fix by selves cause its inside the fridge just remember to shut water off
your cost is just parts
Dec 06, 2008 | Kenmore 54602 / 54604 / 54609 Side by Side...
Installed replacement Icemaker but will not dump new ice...
Either your freezer is not cold enough or you got a defective ice maker. It needs to be 15 degrees or colder to make ice. The water may be frooze but not cold enough to close the internal thermostat inside the ice maker. If your freezer is colder that 15 degrees, take the ice maker back to Sears, you got a lemon. Good luck!, Mack
Jan 08, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
139 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
