Question about NEC VT595 LCD Projector
DLC proyector horizontal black line
Present an horizontal no light wide line with scattered white dots inside the horizontal line
Print problem sir in 2420L
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing.
Happy with us Dial Epson Printer tech support phone number 1-877-778-896 for technical support of customer executive regarding with the Epson printer, if your printer is not connected with your PC & Laptops, Don't worry, dial our Tollfree 1-877-778-8.9.6.9 and get better and feasible solution of your issues within a time in the USA.If you want more information regarding with Epson n printer visit us:http://printertechnicalhelp.com/epson-printer-technicalhelp.html
Nov 25, 2016 | Office Equipment & Supplies
Why my dell 4700c desk top. have dotted horizontal lines on start up?
Try securing the connection between the computer and the display. Try pushing the connector into the ports on both ends. If there are screws on the connectors, make sure they all of them are tightened.
Apr 25, 2014 | Dell Dimension Computers & Internet
Lines on paper C3480 copier
more detail please ?
the line is like what...
horizontal ?
vertical ?
wide of line?
black line or white line ?
Feb 22, 2013 | Canon Office Equipment & Supplies
My MP600 printer prints horizontal stripes on glossy photo paper. Also, a single line of black dots prints vertically. I have deep cleaned the nozzle and realigned the printing. The wide black cartridge...
First your white horizontal lines are due to you not printing in the best quality. Go into the printing preferences and change the quality to best/quality.
The dots printed vertically are possibly due to ink getting onto the star wheels on the doc exit rollers. Also its possible that the printing media is a bit on the thin side and may need to be supported when exiting the machine.
Those should solve your problem. A new printhead wont make any difference.
Good luck
Jul 10, 2011 | Canon PIXMA MP600 all-In-One InkJet...
HP OFFICEJET PRO 8500. BLACK LINE WHEN SCANNING FROM FEEDER, AND COPYING FROM FEEDER, BUT NOT FROM THE GLASS. fROM INSPECTION, ITS A METAL WIRE THAT IS HOLDING A FEW CORDS INSIDE THATS CAUSING IT
This may be dot of dirt on the class that looks like a horizontal line when the feeder moves, to solve it, try this link from hp site: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01619149&cc=us&lc=en&dlc=en&product=3752459 it its something within the glass which you can not clean, contact the hp's repair or replacement options if it is still in warranty.
Aug 25, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Samsung dlp tv. white dots scattered across the screen. never change, always same spots. also appears to have some black dots
your dlp ic is going bad and needs nto be replaced. some of the mirrors are getting stuck they will appear as black dots or white dots. it usually starts as one or two and will continue to get worse over time.
Jan 28, 2010 | Samsung Televison & Video
Projection horizontal lines and flickering
This is the problem I had with a couple of my projectors, one of them I just replaced the bulb and the other needed whole new brains (controller board)
Feb 01, 2008 | Dell 3200MP Multimedia Projector
No picture white screen
check you bulb and your color wheel notorious on this set
Nov 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
Sep 20, 2007 | Mitsubishi CS-35505 35" TV
Beautifull picture except for a jiggling black line in pricure
your tv is having horizontal problem take it to a tech in order that the hrizontak deflection circuit be checked it also might have abad yoke
Dec 28, 2006 | Samsung TXF2899 28" TV
NEC VT595 LCD Projector Logo
29 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
