Question about Nortel Norstar 16-Line PBX Speakerphone
HOW TO PROGRAM PHONE NUMBERS NORTEL NETWORKS PHONE
3 Suggested Answers
consultel1
  • 860 Answers
SOURCE: How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Posted on Apr 16, 2010
  • 277 Answers
SOURCE: How do I set up music (radio from my pc) using headphones on my Nortel Networks phone, model #NTDU91? Is there a feature for that? Thank you
You should call in your local vendor and have this done.
They will need to install a jack that matches your headphone jack and punch it down to a certain pair on the phone system, they will also need to go into configuration programming and set the feature.
Config password and knowledge of wiring and programming required. Note you need to purchase a license to "re-broadcast" music on phone systems, paging equipment etc.
Canada license - http://www.socan.ca/licensees/faq-licensing
USA license - http://www.ascap.com/licensing/
Penalties:
The Penalties
Under U.S.C. TITLE 17, the law allows copyright owners to receive as damages for infringement between $500 and $100,000 for each work infringed
Posted on Nov 06, 2012
How do I program the T7208 telephone to display incoming telephone numbers?
I managed to find the manual, but it does not say a thing about this. I think your provider has to give you the information, with the incoming call. When he switched that information of, your phone can't display it. Sometimes the providers charge you extra for that service. If, on the same extension, another phone did display the number, perhaps hetre is a way to switch it on, but I could not find it.
The link is to the manual.
http://ipf.msu.edu/_files/pdfs/user-guides/norstar-t7208.pdf
Sep 30, 2014 | Nortel Networks T7208 Telephone
How do you transfer a call on a Nortel t7208?
This is usually programmed as one of the 'soft' buttons down the right hand side of the device - subject to the programming of your phone / and the system.
Usually the T7208 is connected to the BCM range of PBX systems - in which case, to transfer a call, you'd use Feature 70. You could, of course, program this into one of the buttons yourself, so you only have to press one button to do so.
Hope this is of use to you. :)
Oct 29, 2013 | Nortel Lands Phones
Penalties:
The Penalties
Nov 06, 2012 | Nortel Lands Phones
How to change the number of rings on calls coming in on the nortel t7318e networks telephone
That will require a programming change for your extension. If you are familiar with programming it is located under the capabilities heading and listed next as Forward NoAnswer - press show twice then next and you can use the CHNG soft key to change the delay before being forwarded.
Oct 01, 2012 | Nortel Networks T7316E Telephone Platinum...
How do i program ip 2033 on nortel system
when you plug it in, and the Nortel logo appears on the screen, swipe the three buttons that are under the display, with your finger, and that will get you into programming.
you will select following
Manual DHCP config? yes
Partial? yes
enter the IP address of your system
for port #: enter: 7000
retries: enter 5
for the rest of the programming select "0" till the end
Aug 23, 2010 | Nortel Networks IP 2033 Audio Conference
I have 4 lines that were made into speed dial numbers then deleted. On this phone (although not other phones on the same network) they now appear as "blank". If calls are put on hold from another phone to...
You call your Nortel service tech, unless you know the installer password and are familiar with programming. You have to go back into set programming and reassign the lines.
May 20, 2010 | Nortel T7316E 2-Line Corded Phone
Press the chg key
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
Forwarding Calls to Outside # for Nortel T7316
You can set divert for the calls to another number. Do check for the call settings and activate the divert based on situation like.. When busy. Not reachable.
Aug 19, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Looking for model number
It's usually above or below the serial number and starts with 'NT.......' while the serial number starts with 'NNT.......'
Sep 11, 2008 | Nortel 2002 IP Phone
Changing name in nortel T7316E handset
We would like to change the name displays on our phones
Mar 05, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel Norstar 16-Line PBX Speakerphone Logo
66 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Oloyede Monsuru
Computer Repairing
Computer Repairing
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
