Question about Samsung Cell Phones
How to dry out a Samsung phone dropped in transmission fluid?
I dropped my phone in transmission fluid now the speakers sounds garbled - how can i dry it out?
2 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: MOTO Razor v3m with bad speaker outgoing.
the microphone on the phone needs to be replaced so take the phone to a mobile repair shop and have it replaced
Posted on Dec 26, 2008
The speaker has become garbled. Listening is possible but difficult.
The speakers cone usually made from polyethelene or fiber can be your problem the only way to fix it is to replace it with a new speaker. Over time cones become brittle and dry out or for a better word rot or decay. This causes crackeling in your speakers sound quality. Hope this helps you out.
Jan 12, 2013 | Toshiba Satellite A105-S4074 Notebook
Tip
No Sound or Garbled Sound on a Nuvi Series GPS
I've seen many posts of "No Sound" or "Garbled Sound" for the Garmin Nuvi Series. This is a common problem with the Nuvi.
In order to troubleshoot this problem, we need to determine if it's a hardware or software issue or a setting issue.
No Sound:
1. Try the obvious. Is your volume setting turned up?
2. Is the sound muted with the mute button?
3. If your Nuvi has a FM transmitter, is it selected to "FM" or "Speaker"? The "FM" setting will mute the internal speaker. Setting it to "Speaker" will send sound to the speaker.
Garbled Sound:
1. Does the sound seem to be better at lower volume settings?
If you still can't hear audio or if the sound is garbled, then we now have to determine if the internal speaker is defective. The easiest way to do this is:
1. Plug a set of headphones into the headphone jack. Now try listening to the sound. Listen for the touchscreen beeps, MP3 audio, voice directions, etc. Try adjusting the volume using the headphones. If you can hear sound through the headphones and it's clear and not garbled, then your internal speaker is defective.
The headphone jack is not only a jack but it's also a switch. When you plug in your headphones, the audio amplifier of your Nuvi is switched from the internal speaker to the headphone jack. When you unplug the headphones, your Nuvi's audio amplifier is reconnected to the internal speaker.
Now, if you can't hear audio through either the internal speaker or the headphone jack, you may have a different problem.
1. The internal audio amplifier (hardware) is defective.
2. There is a software problem. You could try resetting your Nuvi with the reset button or perform a factory reset. The software problem is more likely if you can hear MP3 audio or touch screen beeps but not speech.
The internal speaker has a voice coil. The voice coil is nothing more than a thin piece of long wire, wrapped around a magnet, numerous times. If you can't hear any sound, it is very likely that this coil is "open"; meaning that the wire has broken inside. If the sound is garbled, this is an indication that the speaker is mechanically defective and not reproducing the sound as it should. The speaker has a "diaphram" that moves in and out as it reproduces sound. If the diaphram has been damaged, it can't move in or out like it should and reproduce the sound clearly. There is also a possiblity that the voice coil has shorted windings, meaning that instead of it being a long piece of wire, it's now shorted to its adjacent windings and is electrically shorter now. Again, this can impact the reproduction of sound.
So, why did your speaker go bad?
1. It's possible it was defect in the manufacturing process and failed prematurely.
2. You might have had the volume up too high. I recommend using the lowest volume level possible. High volume levels put greater stress on the diaphram and may overheat the voice coil.
3. A speaker is an electro-mechanical device. It's subject to being damaged if you happen to drop or jar your Nuvi and/or operate it outside of its normal operating parameters.
What's the Next Step?
If your Nuvi is under warranty, I strongly suggest that you contact the manufacturer and tell them what happened. Tell them all of the steps you have gone through to confirm that the speaker is defective. If the warranty is still in effect, they should repair or replace your Nuvi.
If your Nuvi is out of warranty, try calling the manufacturer anyway. You have nothing to lose. Maybe they will replace it anyway.
If you have no sucess with the manufacturer, you will need to take your Nuvi to someone who is qualified in repairing your Nuvi.
I hope this tip has been helpful to you. Feel free to contact me if you have further questions or require further assistance with this problem.
Best wishes,
- Jim
http://www.sharcnet-usa.com
on Oct 01, 2008 | Garmin Nuvi 350 Car GPS Receiver
Tip
No Sound or Garbled Sound on a Garmin Nuvi GPS
No Sound:
Garbled Sound:
Best wishes,
- Jim
on Sep 30, 2008 | Garmin Nuvi 660 GPS Receiver
How to troubleshoot speaker
Hello sir, Hi!, the garble is caused by two things, 1. a bad speaker, 2. a bad power amplifier IC.
To test the Speaker,
Remove the speaker out from the TV, (this needs disassembly stuff) test it using any available portable amplifier. or radio, OR replace the speaker with the same size.
If this does not solve the garble sound, replace the power amp IC. (this really needs skills in electronics.) thats it.
Apr 27, 2010 | Televison & Video
Poor reception
One of the reason maybe one that you told or another may be that your speaker volume is set on low. You can check it out once
or
if you are really a music lover than can go for Nokia xpress music 5380
Mar 07, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Dec 25, 2008 | Motorola Mobility RAZR V3
Sammsung s4253 plasma tv audio garbled on digital channels
I had the same problem with my S4253 using Directv. I then turned off the Dolby Digital on the sound settings on the Directv satellite box. Problem went away.
Oct 04, 2008 | Samsung HP-S4253 Television
Nuvi 350 Garbled voice
How is the other sound? Like MP3 sound? Is it garbled there? Try using headphones. If the sound is good there, then your internal speaker is bad.
Email me at ks3r at sharc dot net if you are interested in me fixing this for you.
- Jim
Sep 10, 2008 | Garmin Touch Screen GPS Receiver
Cell Phones Logo
20 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
