Question about Hubbell Electrical Products 1 Gang Receptacle or Toggle Switch Cover
I need a postlight receptacle - Hubbell Electrical Products 1 Gang Receptacle or Toggle Switch Cover
    Problem Solver:
  • 7 Answers
Http://www.touchandglow.com/Accessories-s/63.htm $15.97
Posted on Aug 05, 2009
Honda powered. Am getting 115V out of one receptacle and one side of the 220 receptacle. The other receptacle is just 17V. Motor runs great. What's up??
If it's not a bad receptacle, then one of the generator windings is bad. A Honda is worth fixing, or at least it's worth selling to someone who only needs 115v. It _is_ worth fixing. Or, it _is_ worth selling ''as is.'' // Fixing, assuming it's not a bad receptacle, will involve returning it to the factory for repair, and it will involve either a new winding or an entirely new generator section. You can call them to ask how they will handle such a repair and get an estimate of cost.
Sep 02, 2015 | Honda Electrical Supplies
Loose jack port can it be replaced
Brian:
No need to replace the jack port... If you look carefully at the side of the receptacle, there are threads on the outside periphery of the receptacle. A small nut threads on the receptacle and tightens down the receptacle (the "port").
Mar 16, 2013 | Computers & Internet
My Holmes modelHCH 6001 won't start. The receptacle is hot so I think it has to do withthe product itself.
It may, but it could also be a faulty receptacle depending on how old it is or the amperage draw from the heater may be to high. Especially, if you have another electric appliance plugged into the same receptacle. That's where you need to start troubleshooting. If the wiring and the receptacle is fine, then there is more than likely an electrical short in the heater or the cord from the heater to the receptacle.
In the meantime, unplug the heater from the receptacle and let it cool while you do the troubleshooting. If you decide to remove the receptacle, be sure to turn the circuit breaker feeding that receptacle to OFF. Or you may have a shocking experience.
Mar 18, 2011 | Holmes Products HCH6001 Heater
I have a 20A GFCI otlet I am trying to replace. After I took the old one out I am left with 3 white wires and three black wires. How do I put it in ?
The easiest answer would be to wire them in the exact same way as they wired before with the prevoius receptacle. However, as I am assuming that is no longer a possibility...
If this is a normal receptacle that does NOT work off of a wall-switch, then I suspect that one of those black wires is the power feed, one of those white wires is the neutral from the breaker, and the other two sets of wire are branch circuits to the other receptacle. If that's the case, connect all three black wires to the receptacles 'hot' screw (probably brass or copper), and connect all three white wires to the receptacle's 'neutral' screw (probably galvanized, silver color).
If the receptacle used to power off of a switch, honestly, a written descipriton isn't going to do it justice. You'll need to understand the role of each three sets of wire before you can wire properly. If that's the case, say so, and I can attempt to walk you through it.
Oct 20, 2010 | Lutron NTR-20-GFCI VAREO 20A GFCI...
Waste toner
You have to "tell" the printer that you have "emptied" the receptacle. Depending on the model of printer, you may either need to replace it, or use the controls on the printer to "logically" do a "reset" operation.
Apr 16, 2010 | Ricoh Aficio CL7200 Laser Printer
The prong on the electricle from the dryer is shaped differently then the wall outlet
You need to get a matching dryer receptacle rated fro 220V and 30 Amps (in the US).
Make sure you have the power off before attempting to replace the old dryer receptacle.
I have seen many dryers connected to oven receptacles in the past. While incorrect this is not dangerous because the oven receptacles are usually 50-60 amp.
Paying a local licensed electrician $50/hr is a fair & safe way to make sure your dryer receptacle is installed correctly.
May 15, 2009 | Whirlpool Dryers
Replacing a receptacle
As always when working with electricity, shut off the power. Use a circuit tester to make sure that the power is really off. Unscrew the receptacle's cover plate; be sure you get a replacement receptacle that's the correct type for your wiring?though most receptacles are standard, aluminum wiring should only be connected to receptacles designated CO-ALR. When installing the new receptacle, connect the black (hot) wire to the brass terminal screw, the white (neutral) wire to the silver screw, and the bare (ground) wire to the green ground screw. Unscrew the receptacle cover plate and unscrew the receptacle. Disconnect the wires from the terminals. Form a curl with a pair of needle-nose pliers so the wires hook clockwise around the screws, then tighten the terminal screws. Screw the receptacle to the box and add the cover plate.
Jan 18, 2006 | APC MasterSwitch Power Receptacle - Power...
Receptacle Doesn't Work
By far the most common problem with a receptacle is that it doesn?t work. Because receptacles are very inexpensive and easy to replace, it makes sense to replace them when they cease to work properly. But before you go to the trouble of buying a new one and installing it, make sure that the old one is truly defective. For a non-working duplex receptacle, first make sure the problem isn't with the appliance or lamp. Some appliances, such as hairdryers, have overload protectors that automatically shut them off if they begin to overheat. Try a second appliance or lamp in the receptacle. If the receptacle still doesn't work, you'll usually find that the circuit breaker has tripped or the fuse has blown, the receptacle has become faulty, or there is a switch that operates that receptacle and it needs to be turned on. The problem is rarely the wiring. 1) Test the receptacle with a second lamp or appliance. 2) Be sure that one half of the duplex receptacle (or the entire receptacle) isn't controlled by a switch in the room. 3) Check the circuit breaker (or fuse) for that receptacle's circuit to be sure it has not tripped (or blown). If it has, reset the breaker or replace the fuse, and try plugging a working lamp or appliance into the receptacle again. 4) If it still doesn't work, turn off the receptacle's circuit breaker, unscrew the cover plate from the receptacle, and use a voltage tester to be sure none of the wires in the electrical box are still "hot." Then check to be sure that the wires are securely fastened to the receptacle's terminals. 5) Look for signs of charring. Replace the receptacle if it looks damaged. 6) Put the cover plate back on, turn the circuit back on, and try the receptacle again. If it still doesn't work, turn the circuit back off, remove the receptacle cover, and replace the receptacle with one that has the same amp and voltage ratings. 7) If this doesn't solve the problem, call an electrician.
Hubbell Electrical Products 1 Gang Receptacle or Toggle Switch Cover Logo
63 people viewed this question
Top Hubbell Electrical Products Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you a Hubbell Electrical Products Electrical Supply Expert? Answer questions, earn points and help others
