Question about Toys
One rear wheel on peg perego gator only spins when in second gear
    Genius:
  • Toys Master
  • 1,508 Answers
Try swapping the suspect motor over to the other side and see if the problem follows, if it does you need a new motor, if it doesn't you need a new gear shifter switch
Posted on Aug 14, 2017
  • 60 Answers
SOURCE: do I need to replace all tires on peg perego john deere
Hi!
On these, only the 2 rear wheels are the gear wheels. You will just need to replace the tires on those with the rubber ones if you choose to go that way.  Good luck!
Posted on Mar 11, 2009
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 156 Answers
SOURCE: I have a peg-perego polaris four wheeler. One
I would take off the wheel that is not spinning and see if the wires have come loose.
My grandson had a polaris 700 and one of the wires had come off.
I needed a gearbox 3 days later (go figure) and I got it at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-batteries.html
These guys help me out with all my toy problems.
Hope this helps
Posted on Jul 17, 2009
  • 29 Answers
SOURCE: Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Posted on Apr 20, 2010
adamfjeld
  • 1508 Answers
SOURCE: how do i change the
remove the center cap of one of both of the rear wheels, then use a 13mm wrench on each side and loosen the botls then pull the tires and axle out, then remove the red plastic pin at the front of the dump bed nad the two black plastic pins at the rear of the dump bed, then lift up the green plastic piece and this will reveal the motors and gearboxes, you'll have to remove the two screws that secure the gearboxes to the frame and the wires that are connected to the motor, then remove the two screws that hold the motor to the gear box, then do this in the opposite order to reassemble
Posted on Jun 12, 2012
Peg Perego John Deere Gator left wheel wont engage in 2nd gear, just replaced both motors and problem still exists. Any help?
disconnect the wires from one of the motors and check to see if it works in all gears, then do this with the other motor, then swap the wires from the left side to the right and vice versa, if both wheels spin in all the gears then you need a new shifter switch
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
Gator wont go in reverse. It will go in both foward gears.
I would check to see if both wheels are spinning in high.
If only one spins, then it may have a loose connection on one of the motors.
You can also get the specific peg perego gator switches from the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
They also have a phone number that you can call them to explain the problem with the vehicle, they seem to know a lot about them.
Hope this helps.
May 05, 2011 | Peg Perego John Deere Gator HPX
Both wheels will not move in high gear, only one wheel will spin, they both work in reverse and low gear
It sounds like you need to replace the peg perego switch assembly for the gator, I upgraded my shifter and it works great now, but I also found the additional switches at http://www.mypegperegoparts.com/
Jun 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Our Peg Perego Gator has a brand new battery yet it won't run. It started out with the reverse not working, then we lost the fast gear and now it doesn't work at all. Any advice?
They also have a phone number that you can call them to explain theproblem with the vehicle, they seem to know a lot about them.
Hope this helps.
Feb 14, 2010 | Peg Perego John Deere Gator HPX
Gator will not go in reverse or low gear only high
Hope this helps.
Dec 17, 2009 | Peg Perego John Deere Gator HPX
Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
Apr 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Peg Perego Gator Ride On Toy
Sounds like the gears are stripped. If a bunch of teeth are missing, only the high speed gear will spin the gears fast enough to move the gator forward. I just bought a used one and found it pretty easy to tear apart and diagnose as similar issue. The gear boxes, located inboard of each wheel contain plastic gears and strip relatively easy if the shifter is moved , during motion from forward to reverse.
Aug 11, 2008 | Toys
Toys Logo
41 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
