Question about Samsung Computers & Internet
How to reset a Samsung RF263 French Door refrigerator "Ice Off" chime after replacing the water filter?
  • 4 Answers
SOURCE: Maytag French Door Refrigerator with ice and water on the door
See the post on Samurai Appliance Repair Man's site http://applianceguru.com/forum1/13035-1.html for instructions on how it's possible to fix the HV Controller Board power supply filter caps for $5 in Radio Shack parts (really!). You need to be able to solder electronic components, or know someone who can. There are 2 power supply filter caps that appear to go bad and the result is the blinking and flapping. I had the same problem and decided I could not wait for a $150 replacement back-ordered board.
Posted on Jul 06, 2007
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Posted on Dec 07, 2008
MNTECH
  • 1543 Answers
SOURCE: Reset Filter Indicator Light is on
Look for your model number from the sticker inside the fresh foods section of the refrigerator, usually on the liner near the door opening. Now, go to http://www.geappliances.com/service_and_support/literature/ to download a use and care manual for your model, as the reset procedure may vary by model. The filter is usually located at the very back right upper side of the fresh foods compartment, but again, it may vary by model.
Posted on Apr 11, 2009
SOURCE: how do I reset the lg water filter indicator light
i fixed the problem by asking my son. he has more patience than i and just held down the button longer and it worked.
Posted on Oct 15, 2009
SOURCE: Front ice/water dispenser stopped working.
I had the same problem. Turned out to be a microswitch under the lever used to activate it. The microswitch fell from the original position so it wasn't turning on anything. I tried gluing into position but the fumes from the crazy glue messed up the switch and I had to replace the whole rig.
The part is under the control display. You can pry it open from the left side.
Posted on Jun 04, 2010
The ice maker is not working and the water dispenser is not working right. I've changed the filter,checked the water supply and reset ice maker and waited 24 hours. What's next?
First make sure you have water going to refrigerator Samsung water filter heads go bad and won't let water thru or it could be the fill valve it's right near the filter
May 30, 2016 | Samsung RF4287HARS French Door...
How do i replace the freezer door handle on samsung rf263
Usually you have to remove all the screws around the inside door panel...which are behind the door gasket, and throug the inside door panel...
May 25, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung RFG298AARS is cylcing between crushed and cubed ice several times a minute and chimes each time it does that!
\it could be that the switch for the ice selection is stuck or just went bad and shorted out. You can check with appliancepros.com to get price of switch and trouble shoot the problem
Apr 07, 2014 | Samsung RFG298HDRS 29 cu. ft. French Door...
Water dispenser very slow
Check the filter and replace if necessary.
Oct 26, 2012 | LG LMX25981ST Four-Door French Door...
After 14 months and 3 refrigerators, I'm giving up. The RF265 and RF263 series refrigerators make loud popping sounds. I've been through two RF265s and one RF263, and they all make the same noise. The...
I have had what sounds like the same problem for over a year with my Samsung RF263 refrig. It makes very loud popping noises like expansion noises when heat hits your house siding or a railroad track. The noises are loud enough that they actually startle people, and our cat. I had a repair man in last May 2013 but no luck.
I finally did a lot of listening, testing, etc. and found the problem. I noticed it would occur whenever the compressor came on. I thought it might be ice build up, so I took the cover plate off over the evaporator in the back of the refrig compartment. There was no ice build up. I then left the cover off and wiring attached and no noise after a day. After a few other trials I added some more weather stripping to increase the distance between the evaporator coils and the cover plate and that help quite a bit but not totally. I still get a pop now and then. Another problem I noticed with this partial solution is that it causes the shelving to not be aligned. A 'V' gap forms between the shelves and they droop a little. I'm still trying to figure out how to fix this but haven't had any good ideas yet.
This is a very annoying problem and a design flaw in my opinion. Whether Samsung has a solution for it I don't know but I plan on checking before my warranty runs out.
Dan
Jan 30, 2010 | Samsung RF265AA Bottom Freezer French Door...
My icemaker in my large French door Samsung refrigerator takes forever to make more ice. Is there some way to increase ice production? It takes 2 to 3 days to fill up the ice bucket. There is nothing in...
There is no way to speed it up..
If the bucket is empty - 2 to 3 days to fill is normal..
It takes somewhere around 37 minuets for new cubes to freeze,, then dump.. Cant make the ice freeze faster..
If it has a inline filter on the water line - replace it.. If it is clogged it could slow the water that is going in..
If you-all use allot of ice and empty it before it catches up - I would suggest getting a bag of ice from the store and put some in the bucket to keep the ice level up..
Have a nice day...
Sep 08, 2009 | Samsung RF265AA Bottom Freezer French Door...
Maytag refrig (french door) water and ice on door stopped working at the same time.
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Computers & Internet Logo
95 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
