Question about OKI C9600hdn Laser Printer
Resetting belt oki 9600 - OKI C9600hdn Laser Printer
Replaced my waste cartridge with a new one and still getting error 357 waste cartridge full
See if your printer has some sort of reset button. contact Oki for tip.
Maybe you have to reload the software in printer. Try also unplugging printer while turned on. Then press and hold the power button for a minute or so. then plug back in and press power button.
Feb 15, 2016 | OKI C9600hdn Laser Printer
Can I reset the belt
How to reset your OKI C3300 C3400 C3600 laser printers ...
? 2:40
https://www.youtube.com/watch?v=czyqKMpy2-E
Oct 6, 2014 - Uploaded by Toner Man
How to reset your OKI C3300 C3400 C3600 laser printers drum unit ... drum message you can install the chip on your drum unit and continue printing. ... Replacing the Transfer Belt on an OkiC3000 Series Printer - Duration: ...
Nov 26, 2015 | OKI C3400n Laser Printer
Oki c5800 belt life reset
It may require a complete service kit, you should check with Okidata to see if there is a kit available or what steps you should take to reset the life counter.
Jan 29, 2013 | Oki Electric Industry Okidata C5500, C5800...
I need to know the size of the IT Belt reset fuse in an Oki c5500
Have you contacted OKI Data? Live customer support is available 24/7 (within the US and Canada) at 1-800-OKI-DATA.
Jan 14, 2013 | OKI C5500n Printer
I've unplugged it, replugged it, and still get "service call 173:fatal error"
check mechanical error on your printer by sending it to the actual technician..
Sep 01, 2011 | OKI C5500n Printer
929 fatal error on my oki 9600 printer
This is a very unusual error. 929 refers to the waste toner motor not running properly. Remove the waste toner bottle and put a hoover to the outlet to the bottle in case the toner is hard and blocking the exit of toner into the bottle.
Jun 30, 2011 | OKI C9600hdn Laser Printer
My Oki C5800 says "Replace Belt, 355: Belt Life" but I was told I could reset it without changing it if it was still good. How?
requires a fuse that sits underneath the transfer belt. However the belt itself would be full of waste toner that would need to be emptied
Jun 30, 2010 | OKI C5800Ldn Led Printer
I have a oki 9600 Fatal error 917
Replace the transfer belt unit. A 917 is a belt **** sensor error.
Jun 19, 2009 | OKI C5150n Led Printer
Oki 9800 230 fatal error
No reset need to fix fault then clears...check toner carts are secure on drums, all their contacts are clean,
Replace Toner Cartridges with Gen OKI new ones... are you using non oki product? Cause Toner carts, thats where I would start looking cause the error is the machine not receiving correct information from a little chip built into the toner cartridges to allow operation to begin.
Dec 07, 2007 | OKI 9800hdn Laser Printer
Error number 172
the problem is on the fuser unit, ther thermistor on it is damaged.
Jun 02, 2006 | OKI C9300 Led Printer
OKI C9600hdn Laser Printer Logo
52 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
