Question about Toys
Peg perego gator only one rear wheel spins when in 2nd gear
    Genius:
  • Toys Master
  • 1,508 Answers
Sounds like a bad motor, try swapping the motor cables to the other side and see if the problem follows, if it does its a bad/loose shifter switch, if it stays on the same side then replace that motor
Posted on Aug 15, 2017
  • 156 Answers
SOURCE: peg perego gator grinding noise?
The Peg Perego Gearbox is the item that would make a clicking noise or grinding noise.
There are two different types.
One is a cross shape and another is a pentagon shape.
If you contact the folks at http://www.shopjandl.com/ they will be able to tell you what type you need. I get all my parts from them because they help me figure the problems out.
Hope this helps
Posted on Jun 09, 2009
  • 29 Answers
SOURCE: Peg Perego Gator won't run.
look for a bad conection on the wires follow them from the battery back to the point of origin
Posted on Apr 20, 2010
adamfjeld
  • 1508 Answers
SOURCE: Peg Perego John Deere Gator left wheel wont engage in 2nd gear, just replaced both motors and problem still exists. Any help?
disconnect the wires from one of the motors and check to see if it works in all gears, then do this with the other motor, then swap the wires from the left side to the right and vice versa, if both wheels spin in all the gears then you need a new shifter switch
Posted on May 22, 2012
adamfjeld
  • 1508 Answers
SOURCE: replaced reverse switch in peg perego because
the polarity is backwards, switch the wires around on the motors
Posted on Jun 14, 2012
adamfjeld
  • 1508 Answers
SOURCE: Peg Perego JD Gator HPX 12V, both rear wheels are newer, they both spin but the toy barely goes anywhere regardless of the traction surface
are you sure both wheels are spinning in all of the gears? I'm guessing you have a bad motor, you can order a new one here http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=150894216724&ssPageName=STRK:MESE:IT
Posted on Sep 20, 2012
May 22, 2012 | Peg Perego John Deere Gator HPX Ride on...
Gator wont go in reverse. It will go in both foward gears.
I would check to see if both wheels are spinning in high.
If only one spins, then it may have a loose connection on one of the motors.
You can also get the specific peg perego gator switches from the guys at
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego.html
They also have a phone number that you can call them to explain the problem with the vehicle, they seem to know a lot about them.
Hope this helps.
May 05, 2011 | Peg Perego John Deere Gator HPX
I have the Peg Perego Gator and when running it will stop. Happens more often in 2nd Gear. Sometimes when pedal it pressed it will make a motion forward and just stop. Could this be in the acceleration...
It might be the peg perego motor in the rear that is going bad, thus causing the fuse to trip. I had the same problem with my kids toy so I contacted a service center for Peg Perego at 1.801.655.0800
They were able to help me over the phone and get the right parts out to me.
hope this helps
Oct 11, 2010 | Peg Perego John Deere Gator HPX
Both wheels will not move in high gear, only one wheel will spin, they both work in reverse and low gear
It sounds like you need to replace the peg perego switch assembly for the gator, I upgraded my shifter and it works great now, but I also found the additional switches at http://www.mypegperegoparts.com/
Jun 03, 2010 | Peg Perego John Deere Gator HPX Ride on...
Our Peg Perego Gator has a brand new battery yet it won't run. It started out with the reverse not working, then we lost the fast gear and now it doesn't work at all. Any advice?
They also have a phone number that you can call them to explain theproblem with the vehicle, they seem to know a lot about them.
Hope this helps.
Feb 14, 2010 | Peg Perego John Deere Gator HPX
Gator will not go in reverse or low gear only high
Hope this helps.
Dec 17, 2009 | Peg Perego John Deere Gator HPX
John Deere Gator 4x2 - Left Wheel doesn't move when in 2nd gear
I would replace the high/low switch and the reverse switch. One time a replaced the high/low switch and the reverse switch quit on me 2 weeks later.
You can also get the Peg Perego Gator Shifter that upgrades the vehicle.
You can get the parts and repair help at this site
http://www.shopjandl.com/kids---baby-ride-on-toys-peg-perego-switches-and-shifters.html
They have helped me several times.
Hope this helps
May 21, 2009 | Peg Perego John Deere Gator HPX Ride on...
Rear wheels-
Both wheels should spin in 2nd gear. Only one wheel may spin in 1st, but if you put a little pressure on the one wheel that spins it should make the other wheel start spinning.
But both wheels should spin in high gear at the same time.
Hope this helps. If there is more help you can also ask these guys at this website. http://www.shopjandl.com/ I get my parts from them and they seem to also work on them as well
Apr 17, 2009 | Peg Perego John Deere Gator HPX Ride on...
Toys Logo
94 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
