Question about Polar Watches
How to delete Polar RS100 Logo - Polar Watches
Tip
Polar Heart Rate Monitor User Manuals
Having Trouble with your Polar Heart Rate Monitor but can't find your manual? Follow this link to download a new copy.
Don't see your Polar on the list, then your Polar is most likely over 12 years old and you will have to contact Polar directly.
USA/ Canada = www.polarusa.com
Rest of the world = www.polar.fi
on Nov 24, 2010 | Watches
How do i get a polar f7 watch band replaced the watch is just over 2 years old
You can get replacement band on amazon, click here and take a look Amazon com polar band replacement. I hope this was helpful, have a nice day
Feb 03, 2012 | Polar Electro POLAR FT40 Heartrate Monitor...
I have a full memory need to delete files and forgot how
Here are some steps to delete a file in your Polar watch.
Deleting a file
1. In the Time of day display scroll up or down until FILE is displayed.
2. Press OK to enter the File mode.
3. Scroll up or down until desired exercise file is displayed. Press and hold
the signal/light button. DELETE FILE and file number are displayed.
4. Press OK. The wrist unit confirms if you want to delete a file
(Are you sure).
5. Press OK to delete the selected file.
6. Press stop to exit the file. Wait appears. The wrist unit rearranges your
file, which takes few seconds.
7. Repress stop to return to the Time of day display
Deleting all files
2. Press and hold the signal/light button. DELETE FILES is displayed.
3. Press OK. The wrist unit confirms if you want to delete all files
(Are you sure).
4. Press OK to delete all exercise files.
5. Press stop to return to the Time of day display
For more information, refer to manual of the watch.
I hope this will be able to help you.
Thank you for choosing Fixya.
Mar 16, 2011 | Polar S S625X Wrist Watch
Reset button has no impact on S120 - no functions available other than time of day
The S120 is now a fairly old watch. When the function buttons and heart rate cease to function this is generally an indicator that the battery needs to be replaced. The buttons themselves can also become worn out or weak of function, in either case you have a couple of options.
1) send in to a Polar Authorized Service center: This is very important, do not take to a normal watch shop. You need the watch properly resealed and handled correctly as well as you may need parts such as a button return spring they will not have. Plus there is a 90day warranty on Polar's repair. You will also need to send in your chest strap just to make sure that is still functioning properly. Battery repair about $15-, new buttons another $10ish, and a chest strap if needs replacing about $25 or $30-. $50-$60 total if everything needs work, but this is just an estimate.
2) buy a new watch unit. The RS100 (the current replacement) is about $100- and is easier to use with a better chest strap.
Dec 28, 2010 | Polar S120 Wrist Watch
New battery needed and fitted to a Polar heart rate monitor
This is really easy to do yourself. Get a CR1632 battery, unscrew the four screws on the back (dont tip the watch as there is a small spring in the watch), unclip the metal band holding in the old battery noting the way 'round the battery is in (minus side up), pop in new battery and push clip back down, when re-fitting the back make sure the spring mentioned earlier lines up with the white sticker with a hole in it on the inside of the watch back, screw down the back. After you have re done all your settings you may need to re-aquaint the watch with the strap, to do this put on the watch and strap, set the heart monitoring going, bring the watch up close to the 'Polar' logo on the chest strap until the time is displayed, should now be all set up.
Andy
Oct 28, 2009 | Polar F4 Heart Rate Monitor Watch
Error after changing battery in polar watch
Follow this link:
http://www.polar.fi/en/support/product_support?product=125
This is original Polar support site.Here you will find all the info available.
Rate me, please.
Mar 28, 2009 | Polar F6 Wrist Watch
Strange symbol
The same thing happened to me, and here is what I found in an online user manual (but not the one delivered with my watch). Switching the Backlight On
Press the Light button and the display is illuminated for a few seconds.
After you have illuminated the display once while exercising night mode symbol (MY WORDS HERE : the "eye symbol") appears in the display. The display automatically illuminates each time you press any button or bring the wrist unit near the Polar logo on the transmitter, until you stop recording the exercise.
Sep 16, 2008 | Polar F6 Wrist Watch
Watches Logo
23 people viewed this question
Top Polar Watches Experts
NOEL
NOEL
David Payne
David Payne
Are you a Polar Watch Expert? Answer questions, earn points and help others
