Question about Dryers
Can't get it apart
Drying making noise when the drum is spinning but can't get back of it
  • 146 Answers
Well can tell you there are wheels that tub rides on most of them are the front bottom. but you do have to pull whole thing out to work on it. they are not difficultt replace.
Posted on Jun 24, 2009
My kenmore 417 wahser making too much noise, it looks like the inner tub hitting the outer plastic housing. How can I fix it?
Have you tried moving the clothes around in the drum to balance the drum BEFORE you was them? If that works, you have solved the problem! Most people forget that when cloth gets wet it gets heavy so leaving the clothes unevenly placed in the drum dry will make a real problem when they get wet!
Dec 26, 2012 | Kenmore Washing Machines
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Drum appears to be loose and makes a lot of noise when on the spin cycle
With the washer empty, spin the wash tub by hand. The drum should be spin true without any noticeable wobbling and spin without much noise. If it wobbles or makes any kind of rubbing or banging noise as you turn it by hand. The problem is that the spider support arms are broken. It is an expensive repair job since the washer has to be completely torn apart and the wash drum needs to be replaced. Get a few estimates before deciding whether to repair or replace. Sorry.
Mar 08, 2011 | Whirlpool AWM6100 Front Load Washer
My maytag model no.mav4755aww makes a whinning sound at the beginning of the spin cycle
Hi
Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.Since you hear whining it means that the bearing is damaged and the seals on bearing are gone too so it rotates without lubricant. It might be possible to hear whining while you rotate empty drum manually...
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. When the bearings have gone bad, the noise is constant the entire time the drum is spinning.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.Then replacing the bearing is suggested.
Let us know if you want something more else accept the solution.
May 22, 2010 | Washing Machines
LG gas dryer DLG0452W drum makes a clicking noise
one of the dry drum baffle screw might be lose are there might be something caught inbetween the dry drum front seal are rear
Apr 24, 2010 | LG DLG0452W Gas Dryer
Front loading kenmore 86983110 makes loud noise when turned on. Think that there is a problem with the belt. I am tryng to take it apart now and do not know how to find the belt
The belt is located at the back of the appliance.
To remove belt you have to remove a panel at the back, on some model you remove top panel first.
The belt does not make loud noise. Loud noise when spinning is usually caused by bad drum bearing, located at the back of the drum.
Regards.
Jul 13, 2009 | Kenmore Dryers
Washing machine has started to make noise. What could be the issue.
could be coupler or bearings on the bottom of the agitator and tub
Jul 09, 2009 | Maytag MER5775Q Electric Kitchen Range
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Would not dry clothes to original dryness. Now drum is making a whinging noise at the drum spin as though its catching on something every time it rotates. Also made a very loud clattering noise as it...
I had this same problem. The drum spins on two small wheel which with the help of the drum belt support the drum. The wheels or their brackets may be broken and need to be replaced. These are accessable by taking the back off the dryer. Best to take the old/broken ones in to insure you get the exact replacement.
May 01, 2008 | Washing Machines
Dryers Logo
Top Dryers Experts
Marvin
Marvin
