Question about Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas String Trimmer TB80 EC
Plug gap for toro tb22ec - Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas String Trimmer TB80 EC
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
CHANGE SPARK PLUG ON TORO CCR 3650 SNOW BLOWER
First disconnect the spark plug wire from the spark plug. Then use a socket wrench to remove the spark plug. Install the new spark plug into the cylinder head and reconnect the spark plug wire. The Toro CCR 3650 uses a NGK BPMR4A plug gapped to 0.032".
Jan 25, 2016 | Toro Garden
What is spark plug gap settings for a toro tb22ec trimmer
You don't have to gap the plugs on 2 cycle and 4 cycle equipment. They are already pregapped. Look at the part number of the plug and go get yourself an E3 brand plug which covers multiple plug numbers...best plugs on the market.
Sep 28, 2015 | Toro Garden
What's the proper gap for a toro mower spark plug
Spark plug gaps for lawnmowers and lawn tractors are not as critical as they are for motor vehicles. Generally, an acceptable spark gap is anywhere between .025" and .035".
May 13, 2015 | Toro Garden
What is the air gap on the toro 20005 serial 250067677
you mean coil air gap ??? spark plug gap ??? should of included the engine numbers because that's not made by Toro !!!
.011 is the coil gap
.028 is the spark plug gap
Oct 12, 2014 | Garden
No spark at plug
27 years of service for an ignition coil is close to amazing. Recent machines using magneto-type ignition systems are doing well if their Chinese-made coils last a couple of seasons.
I'm pretty sure that is what has failed in your Toro and I hope you can get a replacement from really old stock so you aren't doing this again in a couple of years.
A tip: Use something to measure the gap between the magnets of the rotor and the core of the current ignition coil before you remove it and set the gap the same for the new one. Some setups are fussy about that gap.
Jun 18, 2010 | Toro Lawn Mower With Toro Power Tools
Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas String Trimmer TB80 EC Logo
19 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
